Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Honda VFR1200X Crosstourer
DCT Question
07 Jul 22, 12:37 pm
1
2
Go Down
DCT Question (Read 864 times)
t15dja
Crosstourer Member ‐
80
Topic Author
t15dja
Crosstourer Member
Topic Author
Bike: 2020 Highlander
Country:
DCT Question
on:
Mar 25, 2022, 04.51 pm
Hi all, I am new to the Crosstourer having recently purchased a used 2020 Highlander DCT version. It has just done 300 miles from new. My question concerns the DCT gearbox . In D mode and driving normally I am finding that the gearbox changes up very quickly such that it gets to gear 5 by about 25 miles per hour and gear 6 usually well before 30 mph. As a result sometimes the engine frels like it is "labouring", to use an old-fashioned motoring term, especially when I then twist the throttle to accelerate away. Is this normal? I assume there is no "kick-down", like in a car, when you twist the throttle? I know I can select the S mode, but I thought that D would take longer than it does to move up the gears.
I also have a Goldwing DCT and its gearbox definitely longer to reach the higher gears, even in non-sports mode.
Hound
Crosstourer Pro ‐
229
Hound
Crosstourer Pro
Bike: '13 CT DCT SE
City / Town: Connah's Quay
Country:
Re: DCT Question
Reply #1 on:
Mar 25, 2022, 05.46 pm
I had the same experience with my DCT - I rode it in
D
and was convinced there was something wrong with the gearbox. I now use
S
mode most of the time and use the
button to change down if I think it's in too low a gear, or
to change up one gear. You can always change down but the gearbox won't let you change up if it thinks it knows better! 2nd and 3rd gear cope very well between 25 and 50 mph.
D
can be fine if you're just trundling around between 15 and 40 and if you open the throttle it will take off as there's lots of torque in all gears - it'll drop a cog or two if necessary. Don't forget you can override with the buttons too. DCT takes some getting used to in order for you to feel in control.
Additionally, even though yours has such low mileage, it wouldn't hurt to do a gearbox "recalibration". Get the bike up to operating temperature and then switch off ignition. Put the bike on the side stand, or centre stand with rear wheel chocked to stop it rotating. Press and hold the
D
button and switch the ignition on (don't start the bike). As soon as the yellow "engine management" light goes off, release the
D
button. Then, fairly smartly, press this sequence on the DCT switch:
D D N D N
You should then see
D
and
S
displayed on the dash, and
in the gear indicator position will flash slowly (about once every 2 seconds). Now start the engine, but
do not
touch the throttle. After a short time the flashing
D
and
S
will go out.
You have successfully reset your DCT!
t15dja
80
Topic Author
t15dja
Crosstourer Member
Topic Author
Country:
Re: DCT Question
Reply #2 on:
Mar 25, 2022, 10.11 pm
Many thanks for your comprehensive reply! I think I must've been spoilt a bit by the Goldwing DCT gearbox since, as I said, it takes longer to get through the gears and never feels like the engine is labouring in too high a gear...in fact it's DCT box really needs zero intervention from the rider at all. I suppose I was expecting the Crosstourer to behave in exactly the same way. However I now realise a bit more rider input will be required. I guess its something I will get used to with practice.
Hound
Crosstourer Pro ‐
229
Hound
Crosstourer Pro
Bike: '13 CT DCT SE
Country:
Re: DCT Question
Reply #3 on:
Mar 25, 2022, 11.19 pm
I understand that the box "learns" from your riding habits so if you start off with a heavy right hand, the gearchange intervals may change. You also have a newer DCT than mine so it is better tuned and has more than one Sport mode. There's always the option of using the "Triptronic" buttons to gain complete control, of course, but as you say, the Crosstourer's not going to behave like the GoldWing!
Hope you're able to find a happy medium with the CT.
Oregonian
18
Oregonian
Crosstourer Member
Re: DCT Question
Reply #4 on:
Mar 26, 2022, 02.36 am
Sport 3 (three bars) is a good option. Sport 1 (one bar) seems to be what D mode should have been.
D mode seems useless.
Manual shift mode is the one I go with 90% of the time because it is the only option that allows you to keep it in the higher rpms.
t15dja
80
Topic Author
t15dja
Crosstourer Member
Topic Author
Country:
Re: DCT Question
Reply #5 on:
Mar 26, 2022, 09.40 am
I agree...S1 seems much better as a general day to day gear, although may not help the fuel economy much. Perhaps I should almost think of D mode as like an overdrive more useful for higher speed cruising on A roads and motorways?
Pickaxe
88
Pickaxe
Crosstourer Member
Bike: Honda CT DCT
Country:
Re: DCT Question
Reply #6 on:
Mar 26, 2022, 06.18 pm
Originally Posted by
t15dja
My 2018 DCT never reaches 6th at 30mph (calibrated) and mainly stays in 5th on the flat. Yes, it can sometimes feel like the engine is labouring, but in reality, the engine easily copes with D mode and accelerates easily when the throttle is opened progressively. If you open the throttle quickly, the DCT simply changes down (yes it does kick-down) and the acceleration is correspondingly more rapid.
Personally, I use D mode for the majority of my riding and only select the sports modes if I want to make significant progress. It's horses for courses, but unless you need the extra response provided by the S modes, D mode is far more fuel efficient in a bike that's pretty thirsty anyway.
Last Edit: Mar 26, 2022, 06.21 pm by Pickaxe
Hound
Crosstourer Pro ‐
229
Hound
Crosstourer Pro
Bike: '13 CT DCT SE
Country:
Re: DCT Question
Reply #7 on:
Mar 26, 2022, 08.02 pm
Pickaxe, that's interesting - mine (also calibrated) will be quite happy to change up to 6th in
D
somewhere between 30 and 40. Perhaps it's because it's a 2013 bike and your 2018 has a more sophisticated DCT.
1
2
Go Up
Fork Tunnel Wind Noise Fix?
maki
Today
at 09:48 am
Intercom Systems Poll
Accessories and Products
naefuse
Today
at 07:54 am
Which motorcycle suit do you use?
Flightar
Today
at 02:09 am
Side Deflector Kit ?
Flightar
Today
at 02:06 am
Geelong carbon craft
Flightar
Today
at 01:15 am
DCT "S" mode doesnt work well in the mountains
BIGJFH
Yesterday
at 08:15 pm
MCCruise installation
matt28
Yesterday
at 11:45 am
Honda blackbird 25 year anniversary 2022
Events, Meetings, and Ride Outs
DE65Y
Yesterday
at 05:35 am
Wind Buffering
On Two Wheels
Hound
Jul 05, 2022, 12.19 pm
Givi Airflow AF1110 for sale
freddy871
Jul 04, 2022, 07.16 pm
