Author *SOLD*Kaoko HND200 throttle stabiliser  (Read 492 times)
  • Offline haggetty   gb
    • Crosstourer Member  ‐    44
    Offline haggetty
    • Bike: 2018 Manual
    • City / Town: Nuneaton
    on: Jan 22, 2022, 10.43 am
    NOW SOLD
    As my CT has been sold, For sale is my Kaoko  throttle stabiliser/lock.
    This is the HND200 and fitted my 2018, it’s also the one that is specified for earlier bikes.
    There is a different throttle lock - the HND310 but it’s not clear which year(s) that applied to.
    Best to check your bars first. If yours look like mine in the photo (with the notched end) then it will fit.
    The much complained about throttle jerkiness of the Crosstourer was cured for me with this device.
    You can finely adjust it to add as much or as little friction to the throttle as required. I found that adding a little friction totally stopped the kangaroo effect of the constant small throttle movements you get when riding over bumps.
    Add more friction and it holds your throttle steady without you holding onto it, so it’s great on motorways and in town as a sort of cruise control.
    It’s always easy to roll the throttle shut whatever the setting so is perfectly safe.
    Check your bar end before buying.
    Item cost me £100, will sell for £50
    This is how you bar end should look for this part.
    Last Edit: Jan 25, 2022, 12.52 am by haggetty
  • Offline T24
    • Crosstourer Member  ‐    15
    Offline T24
    Re: Kaoko HND200 throttle stabiliser
    Reply #1 on: Jan 22, 2022, 01.40 pm
    I'll take it.
    Send me your details - t24res@gmail.com
    Thanks
