Author Best suspension set up?  (Read 2602 times)
  • Offline Waltz19   gb
    • Crosstourer Member  ‐    20
    Offline Waltz19
    on: Nov 27, 2021, 06.21 pm
    Hi
    Looking to upgrade the suspension on my Dct.
    Best set up for a big guy? ( 21 stone )
    Thanks
  • Offline Pickaxe   gb
    • Crosstourer Pro  ‐    178
    Offline Pickaxe
    • Bike: 2018 CT DCT
    Re: Best suspension set up?
    Reply #1 on: Nov 29, 2021, 11.26 am
    The front suspension is quite coarse and overdamped, so personally I'd go with very little preload and damping on the front, which isn't going to be affected by your weight and provides a more compliant ride.
    The rear is a different matter, so I'd probably start with about 15 clicks of preload and increase if required and 1 turn out on the damping screw.
    Overall the CT handles weight very well so you should find a setting that suits you.
