Author 2013 heated grips wiring?  (Read 1379 times)
  • Offline Dabbers
    • Crosstourer Member  ‐    48
    Offline Dabbers
    on: Jul 11, 2021, 09.37 am
    Hi All,
    Can anyone advise on the following: I'm trying to pre-order the right plugs and or harness to wire in an accessory point/socket on a 2013 CT with Honda heated grips already in situ. Anyone already done this that might be able to advise what I might need as I can't work out if the grips will be hard wired or might be running off a quartet type multi point harness. Long shot I know but if anybody has any pearls of wisdom I'd appreciate hearing.
  • Offline superduper   gb
    • Crosstourer Pro  ‐    141
    Offline superduper
    Re: 2013 heated grips wiring?
    Reply #1 on: Jul 11, 2021, 11.44 am
    If you have honda heated grips fitted I think you will already have the quartet harness,
    you should see a red plug, this is for the 12v socket
    http://www.hgbhonda.co.uk/hgbdaytonashoponline/contents/en-uk/p3957.html
    http://www.hgbhonda.co.uk/hgbdaytonashoponline/contents/en-uk/p3956.html
  • Offline Dabbers
    Offline Dabbers
    Reply #2 on: Jul 11, 2021, 12.39 pm
    *Originally Posted by superduper [+]
    That's what I'm hoping, I planned on obtaining the right plugs to fit into any spare sockets then connect various via these plugs as required. I've found the right plugs (I think) so I'm nearly there.
    wojcimierz
    • Guest
    wojcimierz
    • Guest
    Reply #3 on: Jul 12, 2021, 01.13 pm
    If you have OEM heated grips than you will find red plug under left cowl.
    Personally I've cut it off and replace to kind a universal waterproof plug to fit some better phone holder with fast charge usb integrated.
  • Offline Dabbers
    Offline Dabbers
    Reply #4 on: Jul 12, 2021, 06.41 pm
    *Originally Posted by wojcimierz [+]
    I have a pack of these exact plugs/sockets on route just in case. Either way I'm sure I'll get it sorted. :028:
