Hi Ray, thanks for your reply. Whats broken is the sensor sitting in the caliper hanger, the bolts came out OK but the sensor was stuck solid, it had corroded solid, so i cant remove the carrier without unclipping the sensor plug behind the radiator. I suppose its going to be a very expensive bit. I have checked on ebay etc, i can get one that fits from a few different Honda's but the plugs are different costing 40 to 60 gbp, my question is if i get one of these and cut the wires as to fit my plug will it upset the abs system, secondly are all of these sensors the same ie will my system recognize it. Anyway, lets hope i can get something sorted, must be a answer out there, regards Stitch
