Author GARMIN ZUMO WIRED TO 12V CIG SOCKET?  (Read 1050 times)
  • Offline dogman7   gb
    • Crosstourer Junior  ‐    10
    Offline dogman7
    • Bike: 2020 VFR1200XD
    • City / Town: Eastleigh
    on: May 24, 2021, 07.47 am
    Hi, I have searched here for an answer but no luck. Is there a solution to this? I have a Garmin Zumo 550 and want to plug it in to the 12v socket adjacent to handlebars but I can't find a suitable connector to allow me to use the Garmin clamp as that hides the USB socket which could be used with a simple 12v plug to USB. Can't see any alternative Nav clamp / mount for the Garmin to allow this. Do I have to hard wire this nav in?
    Last Edit: May 24, 2021, 08.18 am by dogman7
  • Offline __Ray__   nl
    • Crosstourer Pro  ‐    435
    Offline __Ray__
    • www.ride4life.nl
    • City / Town: Brunssum
    Re: GARMIN ZUMO WIRED TO 12V CIG SOCKET?
    Reply #1 on: May 24, 2021, 02.43 pm
    What is the problem with that?
    I had the 550 when it just came out and had it for 8 years running directly on the battery.
    Since then i had a 395 and now the XT also directly on the battery.
    I also leave the device in the cradle when parked in the garage, just turn it off. When you don't use the bike for a longer period just take it off to be sure it doesn't run the battery flat.
    Now i have 2 bikes with each their own cradle direct to the battery.
    The Zümo's still are boxed with a car mount with a 12V plug to the USB and a opening in the cradle for that USB plug but i doubt if that cradle is suitable for use on a motorcycle.
    I can be wrong but i have the feeling it might pop out on a bumpy road.
    Offline dogman7
    Reply #2 on: May 24, 2021, 03.33 pm
    Thanks for that. I just wanted to avoid hard wiring it to the battery when there is a 12v switched socket right next to the nav unit and then it cuts power when the ignition is switched off meaning no battery drain risk. I may have to wire it in if no other option and as you say the car cradle which does allow the USB to go in, may not hold it on bumpy roads.
