Author A little question about greasing suspension linkage  (Read 578 times)
  • Offline VFR1200x
    • Crosstourer Junior  ‐    2
    Offline VFR1200x
    on: Apr 25, 2021, 07.46 am
    I asked the same question on another forum and i want to ask you guys here too, so here it goes.
    I took down the suspension linkage yesterday and everything looked fine. The only thing i did was that i took out the pivot collars and put in some extra grease in to the bearings with my finger. I did not remove any of  the dust seals.
    I put all the things together and I noticed that im able to rock the shock arm back and forth with my hand. I have tightened the bolt under the shock absorber with 44 NM and the other 3 nuts and bolts with 64 NM.
    I will and a video so you can understand my problem.
