Author Jack-up Kit  (Read 2216 times)
  • Offline wack   gb
    • Crosstourer Pro  ‐    281
    Offline wack
    • It's not a hobby, it's in yer blood !
    • City / Town: Ollerton
    Jack-up Kit
    on: Feb 25, 2021, 10.03 pm
    Hello folks,
    Has anyone fitted a jack-up kit ?
    If so, was it a success, and which kit did you use.
    Bye for now and tia.
    Wack
  • Offline pehun   fr
    • Crosstourer Member  ‐    95
    Offline pehun
    • Country: fr
    Re: Jack-up Kit
    Reply #1 on: Mar 01, 2021, 09.01 am
    Hello,
    I just mounted a kit to raise the bike.
    3,5cm up at the rear of the bike.
    Fantastic!
  • Offline wack   gb
    Offline wack
    Re: Jack-up Kit
    Reply #2 on: Mar 01, 2021, 12.21 pm
    Hello Pehun,
    Thanks for the response, I've ordered the 35mm kit. I've also decided to fit the Hyperpro progressive rear shock spring upgrade !!
    I'll let byou know how it goes.  :152:
    Bye for now.
    Wack
  • Offline pehun   fr
    Offline pehun
    • Country: fr
    Re: Jack-up Kit
    Reply #3 on: Mar 01, 2021, 12.46 pm
    Where did you ordered the kit?
    I searched for many years, and after a deception with the wilbers kit (witch raised nothing) I found 2 different kit in the mecadata french store.
    I think it's the best upgrade i've done to my bike!
  • Offline wack   gb
    Offline wack
    Re: Jack-up Kit
    Reply #4 on: Mar 01, 2021, 02.43 pm
    Hello Pehun,
    I've ordered from BikefarmMV Motorradtechnik, very reasonably priced !  :169:
    Wack
  • Offline Mav   gb
    • Crosstourer Member  ‐    39
    Offline Mav
    Re: Jack-up Kit
    Reply #6 on: Mar 03, 2021, 05.37 pm
    Is a Jack-up-Kit just giving you a greater gap between the seat and pegs for a more comfortable ride or is there another reason for fitting these?  :087:
  • Offline DE65Y   gb
    • Crosstourer Pro  ‐    282
    Offline DE65Y
    • City / Town: Widnes
    Re: Jack-up Kit
    Reply #7 on: Mar 03, 2021, 07.37 pm
    It's all to do with your inside leg measurement.
    The gap between the seat and pegs remains the same, in both jack up kits and lowering kits, what changes is the ground clearance.
    This is done by altering the angle the swing arm sits at, making the seat either higher or lower.
    But then the bike has to be re-levelled, by either raising or lowering the forks in the yokes, in order to keep the geometry of the bike right.
    In my case my inside leg measurement meant I could only just reach the floor, so I lowered mine 20mm, which actually made a big difference to my confidence when stopping.
    Last Edit: Mar 03, 2021, 07.42 pm by DE65Y
