Author Topic: Tall guy setup  (Read 13889 times)
#48
Offline PeteVieira
  • Country: Portugal
Re: Tall guy setup
Reply #48 on: June 13, 2021, 05:51:01 PM
I've bought PUIG lowering kit, 40mm. now i sit pretty comfortable (1.98cm). however this raise another issue. the brake pedal become too high, even in the lowest configuration. had to cut it in half and weld it a bit lower, still not perfect but at least i dont need to raise my leg to use the brakes.
The reference for the adapter is this: 20241N
then you can buy whatever extension size and footpegs from the brand you want, i've bought the touring ones
#49
Offline pehun
  • Country: FRANCE
Re: Tall guy setup
Reply #49 on: June 16, 2021, 08:43:27 AM
my footpegs are 1 inch lowering, so a bit less thant 4 cm...
Do you have a link for your lowering kit?
#50
Offline PeteVieira
  • Country: Portugal
Re: Tall guy setup
Reply #50 on: June 16, 2021, 11:02:43 PM
I had to search the reference in the PUIG list and send the email to them directly, as i couldn't find anywhere on earth that would sell it, sorry. the only item you will need is the adapter, with the reference i've stated before, then you can buy the generic pieces (extender and footpeg)
