Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Honda VFR1200X Crosstourer
Suspension, Forks, and Chassis Set-up and Mods
2 inch Rox risers
21 May 22, 00:47 am
1
Go Down
2 inch Rox risers (Read 1371 times)
SleppRock
Crosstourer Member ‐
18
Topic Author
SleppRock
Crosstourer Member
Topic Author
2 inch Rox risers
on:
Sep 22, 2020, 12.45 am
I just installed 2 inch Rox Risers. I really like them - towards me and a little up = perfect for me. I’m nervous as I just hand tugged all the Lines/wiring and installed. Pseudo throttle cable is Tight when I turn full lock. Same for my clutch. I have rode about 3 miles since installing and everything starts/stops and shifts just fine. Question: am I missing something or is this simple upgrade that easy?
I was told when I bought them I really need to unhook everything coming off the bars, install the risers and zip tie everything post riser install.
Plane Dr
Crosstourer Pro ‐
230
Plane Dr
Crosstourer Pro
Bike: 2016 VFR1200xDCT
City / Town: DFW Metromess
Re: 2 inch Rox risers
Reply #1 on:
Sep 23, 2020, 04.49 pm
That's the trick. Remove all the cable brackets and zip tie them back together. It is still pretty tight though.
SleppRock
18
Topic Author
SleppRock
Crosstourer Member
Topic Author
Reply #2 on:
Sep 23, 2020, 08.31 pm
I went back and removed the brackets holding the brake line and ignition wiring then one clamp and one zip tie later It’s done. This handle bar position is excellent for the way I’m on the bike. Thanks for posting as I was told that everything hand to be removed, repositioned and reattached. I was just paranoid that is it was soooo easy.
matt28
Crosstourer Pro ‐
165
matt28
Crosstourer Pro
Bike: 2018 CT manual
City / Town: Kent/Noord NL
Reply #3 on:
Sep 23, 2020, 09.31 pm
Installed brackets made by Japanese company called Zeta. 20 mm higher and moved towards me approx 20 mm.
Did not have to adjust any cables or clips.
Plane Dr
Crosstourer Pro ‐
230
Plane Dr
Crosstourer Pro
Reply #4 on:
Sep 28, 2020, 03.38 pm
That's the trick what risers? 2" are 50mm, that's a fair amount. I had 25mm on it originally and the were easy.
Showkey
Crosstourer Pro ‐
140
Showkey
Crosstourer Pro
Reply #5 on:
Sep 29, 2020, 08.24 pm
2” Riser can cause throttle cable rub and wears even if the cable stays are removed.
Most notable on far left steer.
The rub occurs when the bottom edge of the upper triple clamp rubs on the cable.
See photos with yellow showing contact point and wear.
A riser with any pull back can make the contact point worse.
1
Go Up
Main headlight bulbs upgrade to LED
Maritimer
Yesterday
at 11:50 pm
Delkivic Silencer & Link Pipe
bigbob570
Yesterday
at 09:55 pm
Denali D7 LED
Accessories and Products
Red Boll
Yesterday
at 08:56 pm
Dunlop Trailmax Meridian
Tyres and Wheels
Younger06
Yesterday
at 08:20 pm
tyre availability
Tyres and Wheels
Younger06
Yesterday
at 08:17 pm
Top speed
Younger06
Yesterday
at 08:12 pm
DCT Oil Filter
General Maintenance, Servicing, and Mechanical issues
Pickaxe
May 19, 2022, 06.05 pm
Loose Windscreen
Northumberla
May 19, 2022, 04.41 pm
West Virginia Mtns ride
Daily Ride Reports and Touring
ArthurY
May 19, 2022, 03.57 pm
Sold. Shop Manual 2016 Print Version
mzflorida
May 18, 2022, 09.18 pm
