Author Topic: Details of the BEAST....  (Read 7570 times)
Offline Freaky
  • Bike: XL1000V Varadero
  • City / Town: Singapore
  • Country: Singapore
on: November 11, 2011, 04:08:33 AM
Lets get the ball rolling.... here are specs of the Crosstourer
Specifications – Honda Crosstourer
Engine – 1237cc Liquid-cooled 4-stroke Unicam 16-valve 76° V4
Bore x Stroke - 81mm x 60mm
Compression Ratio - 12:1
Max. Power Output - 95kW / 7,750rpm
Max. Torque - 126Nm / 6,500rpm
Induction – PGM FI, 44mm throttle bodies
Fuel Tank Capacity - 21.5 litres
Transmission – conventional six-speed or dual-clutch semi-auto
Final Drive - Enclosed shaft
Frame - Diamond; aluminium twin-spar
Dimensions (LxWxH) - 2,285mm x 915mm x 1,335mm
Wheelbase - 1,595 mm
Caster Angle - 28°
Trail - 107 mm
Turning Radius - 2.7 m
Head turning angle - 40°
Seat Height - 850mm
Ground Clearance - 180mm
Kerb Weight - 275kg (F: 132kg; R: 143kg) - * 285kg (F: 138kg; R: 147kg)
Front Suspension - 43mm inverted telescopic forks with hydraulic damping, preload and rebound damping adjustment
Rear Suspension - Pro-Link with gas-charged damper, preload and stepless rebound damping adjustment
Wheels – Spoked tubeless rims
Tyres – 110/80-R19 / 150/70-R17
Brakes – Dual Combined ABS, 310mm front rotors, 276mm single rear rotor
*DCT version
All specifications are provisional and subject to change without notice.
Offline Freaky
Re: Details of the BEAST....
Reply #1 on: November 11, 2011, 04:16:30 AM
Looking at it from the front, notice left side of the engine is protruding out making it un proportional.....
Hmmmmm  :084: wonder is the standard cluth models will also be the same or not. FYI to all, all pics of the XT (Crosstourer) are of the DCT model.....
Cheers....  :821:
Offline ojo
  • Bike: VFR 1200XD white
  • City / Town: Stans
  • Country: Switzerland
Reply #2 on: November 22, 2011, 09:33:38 PM
Anybody knows if Crosstourer is "Drive by wire" just as VFR 1200 is ?
Offline Giovannino
  • Bike: Honda Varadero
  • City / Town: Castelbuono
  • Country: Italy - Sicily
Reply #3 on: November 22, 2011, 10:29:01 PM
Oh yes, for sure! :)
Offline Freaky
Reply #4 on: November 23, 2011, 05:58:58 AM
Even if its 'Drive By Wire', there will still be a throttle cable....
Offline Murdock
  • Bike: XL700V
  • City / Town: Rimini
  • Country: Italia
Reply #5 on: November 23, 2011, 09:52:26 AM
uhm.....
Offline Giovannino
Reply #6 on: November 23, 2011, 10:16:22 AM
No more throttle cable, but a potentiometer connected to the CDI.
Offline Freaky
Reply #7 on: November 25, 2011, 04:08:20 AM
 :164: :062:
