Author Maintenance Spreadsheet - Link included  (Read 1086 times)
  • Offline 4walls   ca
    • Crosstourer Member  ‐    49
    Offline 4walls
    • IBA #61020
    • Bike: VFR1200XA
    • City / Town: LowerMainland BC
    • Country: ca
    on: May 23, 2020, 06.54 pm
    I found this spreadsheet a while ago and don't know the exact origin. I think the original goes back to a user named "HARRY" at cog-online.org but the spreadsheet attached here has been modified quite a lot from his original one. I can't take credit for the fancy calculations this spreadsheet does, but it works well if you are faithful in inputing your data.
    Step 1: follow the link to the Google Sheets document
    Step 2: click on FILE and MAKE A COPY
    Step 3: follow the instructions on the spreadsheet to initialize it for your bike's mileage
    You will need Google Sheets to use this spreadsheet. You might be able to copy it over to Excel, but not sure some of the formulas would work properly there.
    Link here
    Last Edit: May 23, 2020, 10.04 pm by Admin
  • Offline MattR   gb
    • Administrator
    • Crosstourer Pro  ‐    115
    Offline MattR
    • Administrator
    Re: Maintenance Spreadsheet - Link included
    Reply #1 on: May 23, 2020, 10.05 pm
    I edited your link as you had an extra "http" within it plus some quotes  :038:
     :821:
