Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Honda VFR1200X Crosstourer
Tyres and Wheels
Changed rear tire - weird feeling
07 Jul 22, 13:44 pm
1
Go Down
Changed rear tire - weird feeling (Read 1738 times)
CT_Ron
Crosstourer Pro ‐
183
Topic Author
CT_Ron
Crosstourer Pro
Topic Author
Bike: VFR1200X (2014)
City / Town: Borne
on:
Feb 20, 2020, 02.36 pm
Question:
Do mechanics do anything with the rim spokes/spoke torque values when they change a tire?
Story:
I believe I had around 50% left on my rear Continental ContiTrailAttack 3 when a f-ing rusted screw murdered it in cold blood two days ago. Thought my caliper was stuck. Pushing the bike out the garage felt like a strongman competition. I figured I'd drive away to break the caliper loose, as I was now running late for work. First corner was enough to figure out what was going on.
I dismounted the rear rim, threw it on the back of my bicycle and off I went to get the same Conti tire fitted (workshop is right next to my workplace
) I reassembled the rear rim yesterday and went to work today. I could really feel that new roundness of the rear and a much better 'flickability'. I pushed the bike left and right until I arrived at work. No problems at all...
I let the workshop check my nut torque values and had them set it to exactly 108nm as I don't own one of those overpriced torque wrenches. I had tighten it slightly under factory settings. When torqueing was done, a fairly confused man interrupted us outside the workshop and sort of forced us to join his religious cult shouting I need this for my own protection or "I'm gone, I'm gone, I'm gone!" (I refused).
I went home. When I came of a long and almost private exit ramp after have ridden 10/15 minutes, while I was cornering and doing 160kmph/100mph like Valentino Rossi's slower brother, the moment I let of the gas in 5/6th gear I thought my rear came off. It felt like I was sliding for a second or two but I wasn't. It scared the F out of me. And either I'm going crazy, but I thought I felt it during a slow corner too a few minutes later. I checked if the damn rear came loose, but it didn't. Rear rim was tight as can be. Pushed the rear wheel front and back, sideways. I pivoted the bike on it's center stand while pushing, so the rim really was bolted down to the drive shaft. Absolutely no movement.
I did the same thing as I always do when I take that exit ramp: Go in hard as it's a beautiful corner > let off gas > come upright > break. I had about 40km/24mi on the new tyre. It's a Continental who claims break-in time is very short because they don't use any release solvents/oils. I'm a firm believer as they also claim warm up time is less than a mile, which is true. And this is my third ContiTrailAttack set.
What can be the cause of this weird sensation during cornering/deceleration. Does Continental lie and is it still a slick tyre? Did the mechanics do something with my spokes when they changed rubber? Am I just stupid for not noticing these forces before? Did the last torque check do anything to my rear rim? Did the crazy man cast a spell on me for refusing his invitation??? Was it a combination of all of the above or am I being hyper alert?
Specs:
- 2.6 bar front (2.5 factory).
- 3.0 bar rear (2.9 factory).
- rear preload set to max as I'm a heavy guy.
- front about medium preload and also running Conti's TA3.
Last Edit: Feb 20, 2020, 02.53 pm by CT_Ron
Banksy
Crosstourer Pro ‐
109
Banksy
Crosstourer Pro
City / Town: Torbay
Re: Changed rear tire - weird feeling
Reply #1 on:
Feb 20, 2020, 04.49 pm
Think I'd get another 25/30 miles on the tyre first. 24 miles sounds a bit quick for a proper scrub on the tyre..
oskar
Crosstourer Pro ‐
138
oskar
Crosstourer Pro
Bike: VFR1200XH
City / Town: Oviedo
Reply #2 on:
Feb 20, 2020, 09.00 pm
Is the direction of rotation of the tire in the correct direction?
With the motorcycle on the center stand, does the rear wheel rotate freely without friction on the rear caliper?
Or maybe 40 km of taxiing are few to remove the paraffin that the new tires carry.
Superjeap
Crosstourer Pro ‐
375
Superjeap
Crosstourer Pro
Bike: VFR1200XD
Reply #3 on:
Feb 23, 2020, 10.21 am
Too much tyre-lube used for mounting the tyre on the rim?
Martymouse
Crosstourer Master ‐
592
Martymouse
Crosstourer Master
Bike: VFR1200X DCT
City / Town: Holywell
Reply #4 on:
Mar 06, 2020, 02.45 pm
I would go for Banksy's view.
Whilst a new tyre/tire is rideable, it needs a good 100 miles or so of slightly less frenetic riding to fully scrub it in.
Matlock
Crosstourer Pro ‐
124
Matlock
Crosstourer Pro
Bike: VFR1200X
City / Town: Liverpool
Country:
Reply #5 on:
Mar 06, 2020, 11.02 pm
Yep, assuming the wheel is fitted correctly, the tyre rotation is correct and the tyre isn't covered in tyre fitting lube, my guess is that it will just be too much, too soon for the new tyre.
My tyre fitter, who has worked in the industry for many years, reckons you should "run in" a tyre for at least 100 miles, gradually increasing acceleration, braking force and lean angle as you progress. Also go through at least two heat cycles e.g. ride, allow to cool, ride again, allow to cool. That advice has certainly worked for me over the years.
CT_Ron
Crosstourer Pro ‐
183
Topic Author
CT_Ron
Crosstourer Pro
Topic Author
City / Town: Borne
Reply #6 on:
Mar 06, 2020, 11.48 pm
Thanks all. The weird feeling has been solved. It was a combination of several factors: indeed what everyone is saying, run in was still too short despite Continental saying it's super short, cold weather, obviously too much throttle and my rear preload being maxed out, yet my front on the soft side made it all feel weird at the same time.
I actually felt it again just now coming back from work at 00:45, with temperature near freezing point. I felt like I was sliding sideways again. That corner is very weird...
1
Go Up
Fork Tunnel Wind Noise Fix?
maki
Today
at 09:48 am
Intercom Systems Poll
Accessories and Products
naefuse
Today
at 07:54 am
Which motorcycle suit do you use?
Flightar
Today
at 02:09 am
Side Deflector Kit ?
Flightar
Today
at 02:06 am
Geelong carbon craft
Flightar
Today
at 01:15 am
DCT "S" mode doesnt work well in the mountains
BIGJFH
Yesterday
at 08:15 pm
MCCruise installation
matt28
Yesterday
at 11:45 am
Honda blackbird 25 year anniversary 2022
Events, Meetings, and Ride Outs
DE65Y
Yesterday
at 05:35 am
Wind Buffering
On Two Wheels
Hound
Jul 05, 2022, 12.19 pm
Givi Airflow AF1110 for sale
freddy871
Jul 04, 2022, 07.16 pm
