Author Topic: Engine surging while cruising  (Read 5938 times)
#8
  • City / Town: Estero
Re: Engine surging while cruising
Reply #8 on: January 02, 2020, 07:28:50 PM
*Originally Posted by Showkey [+]
( Forgot to mention) One DIY check:
Battery condition ( charged, able to hold a charge) and battery terminal check ( clean and tighten) modern bikes do not like inconsistent voltage supply and the symptoms vary widely and can be intermittent.
Agreed.  I was thinking that too but I don't have enough technical knowledge to be of any value on that particular topic...fear of opening a rabbit hole.  I had the same thing happen to me but on a DCT.  It was the battery terminals, on a brand new battery, that were bad and caused the issue.  I was not sure if it would produce the same results on a manual version.
#9
Offline GA VFR
  • Bike: too many
  • City / Town: Alpharetta, GA
Reply #9 on: January 03, 2020, 02:21:08 AM
I ride all of my motorcycles every week, there for no battery tenders utilized. I will check battery/terminals and connections tomorrow morning.  Current battery original, battery appears to hold charge, never a jump needed to date.
Follow your front wheel
#10
Offline GA VFR
  • Bike: too many
Reply #10 on: January 03, 2020, 02:33:05 PM
Both connections (-+) tight and no corrosion present.
#11
Offline GA VFR
  • Bike: too many
Reply #11 on: January 06, 2020, 01:29:38 AM
Check engine light is not on.  Scheduling trip to the Honda Hospital (stealer) hopefully expense covered under warranty or extended warranty, fingers crossed!
#12
Reply #12 on: January 28, 2020, 01:28:33 PM
Any updates ? Was the bike fixed ?
#13
Offline GA VFR
  • Bike: too many
Reply #13 on: January 28, 2020, 10:41:15 PM
Not yet, hopefully this weekend!  The bike cranks and idles fine.  When upshifting and in between gears the engine cuts out/doesn't maintain revs
#14
Offline Funbobby
  • Bike: 2017 VFR 1200XD
  • City / Town: Navarre, FL
Reply #14 on: February 13, 2020, 12:47:49 PM
*Originally Posted by GA VFR [+]
I’m curious as to what the Honda tech determined your VFR problem was. Any updates @GA VFR?
#15
Offline GA VFR
  • Bike: too many
Reply #15 on: February 14, 2020, 01:44:39 AM
Nothing yet, we have had family issues to deal with not allowing me time to tow it to the shop.  I will let you know when we drag it in to MMS.  BTW where is the throttle positioning sensor?  I will try to tap on it or check connections
