Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Honda VFR1200X Crosstourer
General Maintenance, Servicing, and Mechanical issues
fallo cambio DCT
21 May 22, 00:51 am
1
Go Down
fallo cambio DCT (Read 3183 times)
miguel1200x
Crosstourer Junior ‐
2
Topic Author
miguel1200x
Crosstourer Junior
Topic Author
fallo cambio DCT
on:
Nov 05, 2019, 12.23 pm
hola, tengo un problema en el cambio automático de mi crosstourer no pasa de segunda velocidad y sale el "-" parpadeando , cuando apago contacto y enciendo hace este ruido:
que se quita girado la rueda trasera y pone el punto muerto, pero al iniciar la marcha de nuevo vuelve a salir el guion y ya no pasa de 2ª
he mirado secuencia de fallos y salen 62 (6- largos y 2- cortos) referente a sensor de presion de aceite pero he cambiado uno por otro ( lleva dos de marchas pares e impares) y no se soluciona
Yasko
Crosstourer Master ‐
1361
Yasko
Crosstourer Master
Bike: Africa Twin DCT
City / Town: Canterbury
Country:
Re: fallo cambio DCT
Reply #1 on:
Nov 05, 2019, 04.00 pm
Translated
Hello, I have a problem in the automatic change of my crosstourer does not pass second speed and the "-" flashes, when I turn off contact and turn on it makes this noise:
that the rear wheel is turned off and puts the neutral, but when starting the march again the script comes out again and no longer passes 2nd
I have looked at the sequence of failures and 62 (6- long and 2- short) referring to the oil pressure sensor come out but I have changed one for the other (it has two of odd and even gears) and it is not solved.
Intenta restablecer el DCT ( try resetting the DCT)
oskar
Crosstourer Pro ‐
138
oskar
Crosstourer Pro
Bike: VFR1200XH
City / Town: Oviedo
Reply #2 on:
Nov 06, 2019, 12.57 pm
Hola Miguel, siento mucho no poder ayudarte más que en lo que se refiere a la reinicializacion del embrague DCT, te lo adjunto abajo en pdf, a ver si te sirve de algo. Saludos.
Translation:
"Hi Miguel, I am very sorry to be able to help you only when it comes to the re-initialization of the DCT clutch, I attach it below in pdf, to see if it helps you. Regards."
Stevensweert
642
Stevensweert
Crosstourer Master
Bike: VFR1200 X CT DCT
City / Town: Stevensweert
Reply #3 on:
Nov 06, 2019, 02.00 pm
I don’ t speak Spanish but some years ago I had the same problem.
A firm sweep of the back wheel solved the problem. After that I heard the gearbox going back to neutral. I can not remember whether I did that with contact on or off. So a firm
Sweep at the back wheel (can not remember forward or backwards, so I would say try both; I would start with forward).
1
Go Up
Main headlight bulbs upgrade to LED
Maritimer
Yesterday
at 11:50 pm
Delkivic Silencer & Link Pipe
bigbob570
Yesterday
at 09:55 pm
Denali D7 LED
Accessories and Products
Red Boll
Yesterday
at 08:56 pm
Dunlop Trailmax Meridian
Tyres and Wheels
Younger06
Yesterday
at 08:20 pm
tyre availability
Tyres and Wheels
Younger06
Yesterday
at 08:17 pm
Top speed
Younger06
Yesterday
at 08:12 pm
DCT Oil Filter
Pickaxe
May 19, 2022, 06.05 pm
Loose Windscreen
Northumberla
May 19, 2022, 04.41 pm
West Virginia Mtns ride
Daily Ride Reports and Touring
ArthurY
May 19, 2022, 03.57 pm
Sold. Shop Manual 2016 Print Version
mzflorida
May 18, 2022, 09.18 pm
