Author Honda Heated Grips 3 stage  (Read 1065 times)
  • Offline Fat Bert   gb
    • Crosstourer Master  ‐    835
    Offline Fat Bert
    • Buggering about in West Wales
    • Bike: 13 CT DCT Black
    • City / Town: Tenby
    on: Aug 26, 2019, 01.03 pm
    Have stopped working!
    Red LED still lights so the controller is getting power and handlebar switch still toggles between stages
    No evidence of broken cable
    Any ideas?
  • Offline Showkey   us
    • Crosstourer Pro  ‐    144
    Offline Showkey
    Re: Honda Heated Grips 3 stage
    Reply #1 on: Aug 26, 2019, 09.45 pm
    1.  Resistance check the each grip and compare to shop manual spec.  7.4-9.0 ohms. This is confirming the heating element in each grip is intact.
    2. Check voltage going to the grips from the controller.
    Shop manual has 9 other troubleshooting tests to verify the wiring, connections, power/ground.
    Be sure to drive the bike when testing the grip heating.......there‚Äôs a ( charging) voltage threshold before the grips turn on even when the grip light is lit.  Meaning at idle the grips may not heat by design.
    Last Edit: Aug 26, 2019, 10.05 pm by Showkey
    Offline Fat Bert
    Reply #2 on: Aug 26, 2019, 11.00 pm
    Thanks Showkey  - appreciate that :-)
