Author Topic: dct creeping forward  (Read 1367 times)
Offline x11
  • Bike: Highlander dct
  • City / Town: Lincolnshire
on: August 24, 2019, 03:44:01 AM
Anyone else had this happen? I pulled up to the pump at a filling station today, after a slow 40/60 mph ride in traffic, when I released the brake to turn off the ignition the bike started to move forward, I could not hold it back without re-applying the brake,the engine speed was normal tickover  but the bike was acting as though I had just opened the thottle to make a steady getaway. this has only happened once and after  refuelling it was back to normal for the rest of the ride.. 2014 model dct 16,000 mls
Offline marcparnes
Re: dct creeping forward
Reply #1 on: August 24, 2019, 02:07:57 PM
The clutches are controlled hydraulically which involves sensors, valves and an ESU any of which could have burped. Even though it went back to normal I would run through the DCT Clutch Initialization Procedure just to be sure everything is synced properly. It only takes a minute or two and and is a good thing to do periodically anyway. I do it whenever I change the oil on this bike and my DCT Wing. Here it is below from someone else's posting:
DCT RESET
The engine has to be up to temperature.
Make sure the transmission is in N to start
Engine is off, ignition switch is off
While pressing D, switch the ignition on, wait until the yellow ‘engine' symbol goes out on the dash, then release D
Press in fast sequence: DDNDN
On the dash, the letters D and S should appear together
Start engine, allow it to idle
After a few seconds, the letters D and S should go out.
Stop the engine.
Restart the engine and press D to insure the transmission goes into gear.
Marc Parnes
2018 Goldwing DCT Tour in Red
2020 BMW R1200GS
A Life of Bikes
AMA Life Member
Offline x11
Reply #2 on: August 24, 2019, 03:43:21 PM
*Originally Posted by marcparnes [+]
DCT RESET
Stop the engine.
Thanks for that information, Im due a 16,000 service so will reset after changing the oil.
Nothing to do with the bike but just as Im typing this reply, theres a WW2 Lancaster bomber doing a demonstration flypast for 1940s fete in a nearby village ,its just flown low over my house twice and boy do those engines sound nice.
Last Edit: August 24, 2019, 03:55:06 PM by x11
Reply #3 on: August 25, 2019, 01:36:25 PM
Prime suspect for an intermittent or one time creeping forward event would be........the engine not returning to base idle setting.  Cause.......cable routing, manual cruise device holding throttle open slightly, bar end issue, grip issues????
Offline hoppicker
  • Bike: BMW K1 R80GS
  • City / Town: STAPLEHURST
Reply #4 on: August 25, 2019, 09:08:08 PM
I totally agree with marcparnes. A very simple procedure which can cure various DCT problems.
VF1200X  XRV750 AFRICA TWIN
BMW K1 HONDA SH125i
BMW R80GS BMW R75/6
Offline Vform
  • Country: Canada
Reply #5 on: September 03, 2019, 11:41:52 PM
Thank you so much Marc for publishing the DCT Reset processing
It really improved the smoothness of my beloved  2016 VFR1200X DCT
Sure it's not like a full control of a clutch lever on a Standard VFR  but it is a remarkable improvement
I will keep the info on the bike to be able to remake it as I will need
Thumb's up
Jean
  • City / Town: PacNW
Reply #6 on: September 06, 2019, 12:50:51 AM
Here is the procedure as outlined exactly in the actual Honda Service Manual.
DCT CLutch Initialize Learning:
Offline Vform
  • Country: Canada
Reply #7 on: September 06, 2019, 01:40:27 AM
Thanks Dembones
After 68 K km , finally I can appreciate the full potential of the DCT , especially on controlling the slow move and U-turn
Every owner of a Crosstourer DCT  and may be also the NC 750 DCT  should know and execute this procedure once a year
I'm so grateful
Jean
