Author Topic: Changing grips and leaving OEM heat in place?  (Read 2457 times)
  • Offline DEMBONES
    Offline DEMBONES
    • Bike: 2016 VFR1200XD
    • City / Town: PacNW
    on: Apr 15, 2019, 11.19 am
    I have the OEM 5 position Honda heated grips on my CT.  They came pre-installed from the dealer I bought from in 2016 and I have no desire to disconnect them or change to aftermarket (Oxford, etc.)  I do however have a desire to switch the OEM grips out to an aftermarket set and was wondering if anyone here has done the procedure successfully w/o damaging the heating elements?  Is it just a matter of carefully cutting off the stock grips w/o damaging the glued on heating elements or will I likely find the heating elements also stuck to the inside of the grips and therefore not reusable?
    I also have a Kaoko throttle lock so any grip installation complexity is slightly increased because of that as well.
    TIA!   :020:
  • Offline Plane Dr
    • Crosstourer Pro  ‐    223
    Offline Plane Dr
    • Bike: 2016 VFR1200xDCT
    • City / Town: DFW Metromess
    Re: Changing grips and leaving OEM heat in place?
    Reply #1 on: Apr 15, 2019, 01.23 pm
    I was wondering the same thing.  There is an oversized grip set for BMW's for that.  I was considering a set of them.
  • Offline DEMBONES
    Offline DEMBONES
    Reply #2 on: Apr 15, 2019, 02.47 pm
    My OEM grips are pretty much shot (with only 10K miles.)  I never was impressed with their feel and size (too small for my big mitts.)
    I'm looking at the ProGrip 714.  My favorite grip of all time.  They are perfect for me.
    Reply #3 on: Apr 15, 2019, 03.46 pm
    I changed my OEM grips for Oxfords.
    If I recall the elements are part of the grips, I doubt you could remove them without removing the element.
  • Offline GarySN
    • Crosstourer Pro  ‐    173
    Offline GarySN
    Reply #4 on: Apr 15, 2019, 03.58 pm
    *Originally Posted by DEMBONES [+]
    These should work for what you want, but you'll need to work out the wiring.
    https://www.amazon.com/Heat-Demon-External-Motorcycle-210019RR/dp/B001AWRCJO/ref=sr_1_4?crid=21FVNZ3IPKLG1&keywords=heat+demon+heated+grips&qid=1555340225&s=gateway&sprefix=heat+dwemon%2Caps%2C612&sr=8-4
    Reply #5 on: Apr 15, 2019, 04.58 pm
    Just wondering, if you cut off the OEM grips but can retain the heating element how will you control the grips as the switch is part of the LH grip?
  • Offline DEMBONES
    Offline DEMBONES
    Reply #6 on: Apr 15, 2019, 06.07 pm
    Is it? That's precisely the kind of thing that has me posing the question. You guys aren't sounding like it would work. Surely someone has tried?  :187:
    Reply #7 on: Apr 15, 2019, 09.41 pm
    Dembones,
    The controller is built in as in the image:
