Author Topic: This helps the sensitive throttle  (Read 13748 times)
  • Offline marcparnes
    • Crosstourer Member  ‐    73
    Offline marcparnes
    on: Mar 29, 2019, 12.29 am
    Hi Guys,
    I picked up a new leftover '17 recently and have been working the bugs out of it. The sensitive throttle is definitely something that needs attention. When the Triumph Explorer first was released it had the same identical problem. Back then one of the successful fixes was to coat the handlebar with a very special grease which is used to give stereo controls their smooth feel along with other applications. After a few months Triumph came out with a software update that remapped the throttle and eliminated the problem. On this bike I installed the Throttle Tamer but still felt like it could be better and then remembered I still had some of that grease left over from the Explorer so I disassembled it this morning before going on a 400 mile ride and coated the handlebar with it. What a difference! Much easier to control just like the result on the Triumph. If anyone is interested here is the info on the grease.
    Product: Nyogel 774VH
    Nye Lubricants
    Fairhaven, MA USA
    1-508-996-6721
    www.nyelubricants.com
    Distributed by:
    TAI Lubricants
    Hockessin, DE USA
    www.tai-lubricants.com
    nyoil@aol.com
    Phone: 302-326-0200
    Marc
    Marc Parnes
    2018 Goldwing DCT Tour in Red
    2020 BMW R1200GS
    A Life of Bikes
    AMA Life Member
  • Offline Longdude
    • Crosstourer Pro  ‐    176
    Offline Longdude
    • Bike: Yamaha XT660Z Te
    • City / Town: Exeter
    Re: This helps the sensitive throttle
    Reply #1 on: Mar 29, 2019, 05.29 am
    Interesting post Marc
    I too have a snatcy throttle,  bad in town on my DCT. Found the grease you are talking about, for sale here in the UK.
    https://shop.newgatesimms.com/product/nyogel-774vh/
    May give it a go  :460:
    MoorMan.
  • Offline DaveinNC   us
    • Crosstourer Pro  ‐    247
    Offline DaveinNC
    • Bike: 2017 VFR1200X
    • City / Town: Matthews NC
    Reply #2 on: Mar 29, 2019, 09.46 am
    On the handlebars. Please clarify, you coat the end of the bar before you slide the throttle tube on?
    "Dave"
    If You're Gonna Be Stupid, You Better Be Hard, because stupid hurts!
    Offline marcparnes
    Reply #3 on: Mar 29, 2019, 01.04 pm
    *Originally Posted by DaveinNC [+]
    Yes, you put a very light coat of grease on the entire surface of the bar where the tube goes and then slide the tube back in place. You can experiment with how much damping you like based on the amount of grease you use. I noticed that the Throttle Tamer seems to have a bit more clearance than the OE tube did so I used a bit more grease than I did with the Triumph whose tube fit closer to the bar. Its a permanent fix, once you've applied the grease and reassembled the tube there shouldn't be a need to regrease it in the future as the grease is pretty much captured in place.
    Marc
    Marc Parnes
    2020 BMW R1200GS
    A Life of Bikes
    AMA Life Member
  • Offline oskar
    • Crosstourer Pro  ‐    138
    Offline oskar
    • Bike: VFR1200XH
    • City / Town: Oviedo
    Reply #4 on: Sep 10, 2019, 08.24 pm
    What results are there on those who have applied the grease in the throttle. Thanks.
  • Offline Showkey
    • Crosstourer Pro  ‐    137
    Offline Showkey
    Reply #5 on: Sep 16, 2019, 07.11 pm
    *Originally Posted by oskar [+]
    Think any thing or device that add friction or dampening effect to the throttle tube movement is helpful.   The grease is good because it does effect the throttle return to base idle like a cruise friction device might ( dependence on how the friction device is set and adjusted) .
  • Offline Clazzer
    • Crosstourer Member  ‐    39
    Offline Clazzer
    • Bike: 2016 CT Manual
    • City / Town: Stoke on Trent
    Reply #6 on: Sep 16, 2019, 08.06 pm
    Has anyone fitted grip puppies to see if this is reduces the issue, they increase the grip diameter by almost 25% over standard and so surely an increased movement should in theory help reduce the sensitivity.
    I'm going to nip to J&S to see if I can get a set and I'll fit them on Friday and see if they help.
    Old enough to know better but young enough to do it anyway!
  • Offline Plane Dr
    • Crosstourer Pro  ‐    223
    Offline Plane Dr
    • Bike: 2016 VFR1200xDCT
    • City / Town: DFW Metromess
    Reply #7 on: Sep 17, 2019, 03.19 am
    I did grip puppies and found it helps.  I also thought the base pen grips were to soft and small in diameter
