Author Topic: Super sensitive throttle 2017 dct  (Read 44084 times)
  • Offline Drew66
    • Crosstourer Junior  ‐    12
    Offline Drew66
    on: Feb 10, 2019, 09.03 pm
    Hi I have a 2017 model year dct and think the throttle is super sensitive, its either off or on with what appears to be no transition between both. Also when riding along and just maintaining speed it wants to either accelerate or decelerate. Has anyone do so noticed this and what could the issue be apart from the obvious rider factor. The bike is new and has only 240 miles on the clock so will be going back for its first service in a few weeks depending on the weather but would like to know if anyone else has experienced this.
    Many thanks
  • Offline Fredz   au
    • Crosstourer Pro  ‐    118
    Offline Fredz
    • Country: au
    Re: Super sensitive throttle 2017 dct
    Reply #1 on: Feb 11, 2019, 12.52 am
    I haven't but why wait until first service when they will charge you adjusting it.  I'd take it back now and get em to correct it as it at their cost.
    Reply #2 on: Feb 11, 2019, 07.28 am
     Hi Drew, does it do the same in manual mode,? Is the idle speed correct with a warm engine temperature? Does it do it in drive and sport mode?
  • Offline mondeoman
    • Crosstourer Pro  ‐    203
    Offline mondeoman
    • Bike: vfr1200X
    Reply #3 on: Feb 11, 2019, 02.52 pm
    My 2018 DCT new in April has always been perfect.  :028:
  • Offline smalle10
    • Crosstourer Member  ‐    24
    Offline smalle10
    • Bike: Soon Crosstourer
    • City / Town: NYBORG
    Reply #4 on: Feb 11, 2019, 05.03 pm
    I rented a 2017 no DCT and drow 2200 km in the Alps. When in 2 and 3 gear on bad roads, the bike was jumping like a bull because off the sensitive throttle.
    Per
  • Offline Vform   ca
    Offline Vform
    • Country: ca
    Reply #5 on: Feb 11, 2019, 05.11 pm
    Hi  Drew66
    I have a 2016 DCT  and I experienced a kind of loose throttle handle(freeplay) when I bought the bike
    Talking with the salesman , he told me that this bike is  ''throttle by wire '' but it is a cable from the throttle handle down to the throttle body
    The manufacturer deliver these models and others with a kind of loose or inactive throttle for the first 4-5 mm of the throttle handle
    You can adjust that freeplay with the adjusting nut on the cable just below the throttle handle
    If you look closely under the commodo you will see the throttle cable (the other is and electric cable ) wich is covered by a rubber protection tube
    Pull (slide 10 - 12  cm ) that protection tube toward the engine and you will see that adjusting nut with it's lock nut
    Then you can use your open tool 10mm and 8mm  to slacken the lock nut and hand adjust (reduce to none) that freeplay at the throttle handle grip
    That solved my irrigularity situation
    Hope it will help
    Jean
  • Offline Jarrett
    • Crosstourer Member  ‐    34
    Offline Jarrett
    • Bike: VFR/AT/NC700X
    Reply #6 on: Feb 15, 2019, 12.35 pm
    My 2016 VFR1200X is definitely more throttle sensitive than my 2016 Africa Twin, which I bought first.  At first, it seemed like an issue, but over time I've adjusted my hand to compensate for it.
    One thing I've noticed I do is slide the outside bone of my palm past the throttle to a fixed point on the grip.  That seems to immediately taking the jerkiness out for me.
    The funny thing now is when I get on my Africa Twin, I feel like the the throttle is not responsive enough after being on the VFR :)
  • Offline GADGET
    Reply #7 on: Feb 18, 2019, 07.29 am
    *Originally Posted by Drew66 [+]
    Many thanks
    Drew, Its you, I have had 3 Crosstourers and they have all been the same, the throttle is very direct, you will get used to it  :169:
