Author Topic: Aftermarket windscreen still use factory adjust lever?  (Read 4903 times)
  • Offline Thork
    • Crosstourer Junior  ‐    13
    Offline Thork
    on: Jul 17, 2018, 09.41 pm
    Very close to ordering a Powerbronze tall shield from the UK, and just wondering if I will still be able to use the factory height adjust lever?
    I see pictures of this screen on another thread but can't tell if you can still adjust it up and down.
    Does anybody know?
    Thanks!
    Re: Aftermarket windscreen still use factory adjust lever?
    Reply #1 on: Jul 17, 2018, 10.27 pm
    Hi Thork,
    Just be aware that this screen will probably not fit your bike.
    You may not be aware that prior to 2016 the CT screen was different and was not adjustable with a lever, the mounting holes on 2016 model onwards are different.
  • Offline Thork
    Offline Thork
    Reply #2 on: Jul 17, 2018, 10.37 pm
    Oh, I see... Perhaps I'll keep searching for one specifically designed for 2016.
    MRA looks like they make one for the 2016.
    I guess my question remains.
    Assuming I find one made for 2016+ would it still utilize the factory adjustment?
    Let's say with the MRA Vario Touring Screen:
    https://www.revzilla.com/motorcycle/mra-variotouringscreen-windshield-honda-vfr1200x-2016-2017
    Open to other suggestions for taller screens for the 2016 that retain the factory adjustability!
    Thanks!
  • Offline Vform   ca
    • Crosstourer Member  ‐    24
    Offline Vform
    • Country: ca
    Reply #3 on: Jul 18, 2018, 12.56 am
    Hi  Thork
    I am 6 feet tall and I order  the Medium CalSci screen for my CT 2016, last year
    With the Honda factory level adjustment mechanism I still have plenty of height possibility
    It fits very easily as replacement of the factory adjustable screen
    Screws and all grummets needed are furnished
    I am very satisfied of the protection (taller and wider for cold wind at spring time or at fall)
    The design is may be questionable .....but what do you need ?
    Jean
  • Offline Thork
    Offline Thork
    Reply #4 on: Jul 18, 2018, 01.58 am
    *Originally Posted by Vform [+]
    Hi  Thork
    Jean
    I guess I don't NEED anything, but it would be nice to have a little more of a bubble of calm air than the stock screen at the highest setting provides.
    I'm 6'5" tall so taller is better for screen replacements.
    Had the tallest Parabellum on my Tenere and it still wasn't quite tall enough.
  • Offline wack
    • Crosstourer Pro  ‐    267
    Offline wack
    • City / Town: Ollerton
    Reply #5 on: Jul 18, 2018, 09.06 am
    Hello folks,
    Not sure how relevant this is to you chaps, but I'm 6'4", and I have the Givi Airflow two piece adjustable screen on my CT, and have found that the highest setting doesn't necessarily produce best results ! !
    Bye for now.
    Wack
  • Offline Maritimer
    • Crosstourer Pro  ‐    171
    Offline Maritimer
    • City / Town: Moncton,N.B.
    Reply #6 on: Jul 18, 2018, 11.09 am
    Hi Thork, I also have a CalSci screen  and I must say it works pretty good, especially with the CT adjustable windscreen option. When it gets hot, I drop the screen and when I need more protection, I bring it up. I find it gives me more protection to the shoulder area compare to the original windscreen.
  • Offline DEMBONES
    Offline DEMBONES
    • Bike: 2016 VFR1200XD
    • City / Town: PacNW
    Reply #7 on: Jul 18, 2018, 08.42 pm
    *Originally Posted by Maritimer [+]
    How tall are you and which size did you buy?
    https://calsci.com/motorcycleinfo/VFRprod.html
    Touring Shields for 2016+ VFR
    WH = 15"
    WL = 22"
    Size   Price
    Stock WH = 11", WL = 17.5"         10.5"
    VFR 2016+ XLarge   $200    24.5" = 62cm   16.5" = 42cm
    VFR 2016+ Large   $185           23.5" = 57cm   15.5" = 39cm
    VFR 2016+ Medium   $185           22" = 56cm   14" = 36cm
    VFR 2016+ Tinted Shorty WH = 12", WL = 17"   $125   18" = 46cm   10" = 25cm
