Author Topic: New exhaust is bringing on engine management light.  (Read 2922 times)
  • Offline DJ
    • Crosstourer Member  ‐    36
    Offline DJ
    • Bike: VFR1200X manual
    • City / Town: Ballinamallard
    on: Jul 03, 2018, 01.33 pm
    When I bought my crosstourer it already had an aftermarket exhaust fitted. My friend has just bought a VFR1200F and fitted a nice fruity exhaust. He disconnected the cables to the valve in the exhaust like I have done to every Honda I've owned for the last 15 years. However now the bike has brought on the engine management light.  Any idea for a way round this ?
    • Crosstourer Master  ‐    938
    Re: New exhaust is bringing on engine management light.
    Reply #1 on: Jul 03, 2018, 01.52 pm
    Hi DJ,
    Are you saying you disconnected the cable to the Lambda sensor?
    Why... and of course it will put the light on! Plug it back in and let the ECU do its own adjustments.
  • Offline DJ
    Offline DJ
    Reply #2 on: Jul 03, 2018, 02.03 pm
    I didn't fit my own exhaust it was already done but I assume the Crosstourer has the same flap that is cable operated as the VFR1200F.  on all my previous bikes I just disconnected the cables but let the motor run thinking it was operating the flap.
  • Offline DJ
    Offline DJ
    Reply #3 on: Jul 03, 2018, 02.16 pm
    Sorry in answer the lambda sensor is still connected.
  • Offline fotodadi
    • Crosstourer Pro  ‐    140
    Offline fotodadi
    Reply #4 on: Jul 03, 2018, 02.24 pm
    *Originally Posted by DJ [+]
    CT doesn't have the same flap like the FD
    And its strange that disconnecting the cable will turn on the light since the servo motor operating it is still connected (I did exactly this to my VFR with no issues)....or can you confirm that the electrical plug to the servo is still connected? It's underneath the right rear-quarter cowl.
    Worst case, you can pull the codes from the MIL and find out exactly what's responsible for it. :038:
    In My Garage
    www.fdfoundation.org
  • Offline DJ
    Offline DJ
    Reply #5 on: Jul 04, 2018, 06.31 am
    Electrical plug is stil connected.Ive had several Fireblades and A CBF1000 on which removing the cables and changing the exhaust had no issues. Strange.
  • Offline superduper
    Offline superduper
    Reply #6 on: Jul 04, 2018, 10.28 am
    DJ
    if the exhaust was fitted when you bought it, are you sure its the exhaust thats causing the issue, was the light coming on when you bought it?
    (on the 1200F disconnecting the cable was fine but if you removed the servo motor, the engine management light would come one)
  • Offline Juggler
    • Crosstourer Member  ‐    38
    Offline Juggler
    • City / Town: Moscow
    Reply #7 on: Jul 04, 2018, 11.17 am
    Most likely it is EXUP (or whatever honda calls it). We don't have it on x-tourer, but F 172hp version has it.
