Author Topic: Changing brake lever  (Read 2296 times)
  • Offline noddy
    • Crosstourer Member  ‐    53
    Offline noddy
    on: May 12, 2018, 06.35 pm
    Hi All
    Simple question.  I "lowered" my bike to the floor and bent the brake lever and so need to change it.  It seems like there is just one bolt to take out but the throttle cables stop me removing it.
    Can anyone tell me how to change the lever?
    Thanks
    John
  • Offline HoldMyBeer
    • Crosstourer Pro  ‐    124
    Offline HoldMyBeer
    Re: Changing brake lever
    Reply #1 on: May 13, 2018, 03.47 pm
    Hi John  :031:
    Can't recall if I came across any issues when changed mine but was pretty straightforward process. Care to take picture?
    Ged
  • Offline noddy
    Offline noddy
    Reply #2 on: May 13, 2018, 05.08 pm
    Hi Ged
    The throttle cable lower run stops the bolt from being removed.  I could un-clamp the brake master cylinder and move it but I was wondering if there is a simple trick I have missed.  It can't be that hard to change the brake lever!
    Thanks
    John
  • Offline superduper
    • Crosstourer Pro  ‐    140
    Offline superduper
    Reply #3 on: May 13, 2018, 06.41 pm
    noddy,
    peel the rubber cover off the throttle where the 2 throttle cables go into the twist grip,
    you will see 2 lock nuts 1 on each cable(14mm from memory)
    if you slacken them off you can rotate the cable out of the way of the bolt and remove it :028:
    remember to put the cables back,tighten the lock nuts back up after and refit the rubber sleeve
    Last Edit: May 13, 2018, 06.43 pm by superduper
  • Offline noddy
    Offline noddy
    Reply #4 on: May 14, 2018, 04.30 pm
    Thanks for that. I will have a go when the new lever arrives.
    John
    Offline HoldMyBeer
    Reply #5 on: May 14, 2018, 06.02 pm
    Here's how my cables look like, see pic.
    Though I'd never ran in to problems when changed mine.
    Mines 2014 model. Are they routed differently through the years?
  • Offline noddy
    Offline noddy
    Reply #6 on: May 14, 2018, 09.35 pm
    That is certainly different to mine!
    John
  • Offline Martymouse
    Offline Martymouse
    • Bike: VFR1200X DCT
    • City / Town: Holywell
    Reply #7 on: May 17, 2018, 12.04 am
    Looks to me that the throttle cables over the top of the brake lever is just plain wrong  :003:
