Author Topic: Powering the accessories  (Read 12530 times)
#40
Offline Dieselboy
  • Journey not Destination
  • Bike: '17 VFR1200XD
  • City / Town: Tampa
Re: Powering the accessories
Reply #40 on: April 03, 2018, 10:47:57 PM
 :087:
Sorry to report a fail on the test ride.
The up shift works as planned but I lost the down shift.  I unplugged the relay and shifting is back to normal so I have some investigating to do.
The set function did not work either so don't try this at home (yet).
#41
Offline Dieselboy
Reply #41 on: April 04, 2018, 10:38:07 PM
 :028:
Got the set function sorted.  Had to recheck my notes from Prez.  Needed to connect the orange and yellow wires NOT brown and yellow.  Fixed and it functions.
 :084:
Still looking at the up-shift.  Going to try a diode in line and I have a friend bringing over an oscilloscope so we can try to see what's happening.
#42
Offline Dieselboy
Reply #42 on: April 07, 2018, 11:49:27 PM
So found that the down shift button sends 1.9v down the up shift green/blue wire, odd that.  Fancy CANBUS is smarter than I am. So the new plan is to use a comparator and a photo coupler to steal the signal to trip the on/off for the cruise control.
The comparator will block the 1.9v and the photo coupler will use the up-shift 5v to momentarily connect the brown and orange wires of the cruise control.
That's the plan.  But now I have to leave town for a week so the plan is on hold.
Of potential use to someone out there, I had to learn to clear a fault code.  Because of my voltmeter work with the down shift button, the check engine light came on.  So here's how you clear it:
1. Jump brown and green wire at the diagnostic plug using a paper clip.
2. Put the kill switch to “run”.
3. Turn on ignition (don't start).
4. Pull paper clip and reinsert within 5 seconds.
5. Watch confirmation blinks at engine light.
6. Turn off ignition.
7. Pull paper clip.
#43
Offline Dieselboy
Reply #43 on: May 12, 2018, 04:20:54 PM
Bwahahaha!!!! It lives!!!   :007:
I can turn the cruise control on/off by tapping the up-shift paddle.
A friend built the signal-thief-circuit I needed to make my plan work. (I'll post a parts list later.)
It accepts the 5vdc signal sent when I pull the up-shift paddle and momentarily connects the brown and orange wires from the cruise control.
The subtlety of the circuit is that it blocks the 1.9vdc that the down-shift paddle sends to interrogate the same up-shift line. Because my circuit is grounded, without the “block”, the bike would not down shift manually. It thought the up shift was in constant use.
He cut up a waffer and put the components on small  enough area to mount into an automotive relay.
Using RTV, we sealed the components into the relay and installed.
End result: manual shifts work and up-shift triggers cruise control on/off.  :152:
Last Edit: May 12, 2018, 04:36:30 PM by Dieselboy
#44
Offline Dieselboy
Reply #44 on: May 19, 2018, 01:45:01 PM
 :031:. I took the first real ride, about 50 miles. I love the functionality!!! Having the up-shift trigger to on/off and the additional set button is very close to OEM ergonomics. Works like a champ!  :082:
Here's the parts list, as promised:
www.mouser.com
Mouser #: 78-VO618A-4X016
Mfr. #: VO618A-4X016
Desc.: Transistor Output Optocouplers H. Relblty 5300 Vrms 160-
320% CTR, VDE
Qty 1
Mouser #: 821-1N4001G-KR0G
Mfr. #: 1N4001G-K R0G
Desc.: Rectifiers Diode, 1A, 50V DO-204AL (DO-41)
Qty 2
Mouser #: 821-MTZJ2V0SBR0G
Mfr. #: MTZJ2V0SB R0G
Desc.: Zener Diodes zener 500mW 2V0
Qty 1
Mouser #: 603-MFR-25FBF52-220R
Mfr. #: MFR-25FBF52-220R
Desc.: Metal Film Resistors - Through Hole 220 OHM 1/4W 1%
Qty 1
#45
Offline navigator1946
  • Lovin' my 2015 CT Highlander DCT.
  • Bike: Crosstourer DCT
  • City / Town: Hornsea, E.Yorks
Reply #45 on: June 04, 2018, 01:05:21 PM
I've just read this thread in admiration.  By heck, there are some intelligent people on this website. We numpties are so fortunate to have such a valuable resource at our fingertips!  Thanks guys.
Just love my Honda
#46
Offline Dieselboy
Reply #46 on: June 04, 2018, 10:37:36 PM
  :031:
Ta!
#47
Offline Dieselboy
Reply #47 on: May 15, 2019, 01:25:53 AM
Here's an updated schematic with Mouser part numbers included.  35,000 miles and still clocking.... :169:
