Author Topic: Sump plug length.  (Read 1590 times)
  • Offline Gaz
    • Crosstourer Junior  ‐    13
    Offline Gaz
    • Bike: 2016 VFR1200X
    • City / Town: Brisbane
    Sump plug length.
    on: Aug 29, 2017, 09.04 am
    Does anyone know the length of the THREAD of the sump plug? I can get a magnetic one made and I need this info for the manufacturer. I know it is an M12 x 1.5 pitch with a 14mm diameter but not the length of the thread. I have only just changed my oil and don't want to drop the lot just let to measure it.  :305:
  • Offline Fredz   au
    • Crosstourer Pro  ‐    118
    Offline Fredz
    • Country: au
    Re: Sump plug length.
    Reply #1 on: Aug 29, 2017, 10.16 am
    Geez Gaz, not another oil (drain plug length) thread.   :008:   :150:
    Dunno the length but 20-25mm would do the trick.  Can't ya get em at Repco or Supercheap?
  • Offline Gaz
    Offline Gaz
    Reply #2 on: Aug 29, 2017, 11.34 am
    Thanks Fredz. I know but I did a search and couldn't find the thread length. I just put 3.3 l of Penrite fully synthetic 5W-40 oil in last weekend and then thought a magnetic sump plug would be a good idea.  :430:
  • Offline Fredz   au
    Offline Fredz
    • Country: au
    Reply #3 on: Aug 29, 2017, 11.40 am
    *Originally Posted by Gaz [+]
    Gawd Gaz, now you've really turned it into an oil thread.  :156:   :164:
    You shoulda used this stuff   :745:   :745:   :745:
    http://www.penriteoil.com.au/products/mc-4-full-synthetic-10w-40
    Last Edit: Aug 29, 2017, 11.46 am by Fredz
  • Offline Gaz
    Offline Gaz
    Reply #4 on: Aug 29, 2017, 12.19 pm
    Well Fredz. Mine is JASO M1 with full zinc and I got 5 litres for $50. So when I buy the next lot I will have enough left over for a third oil change.  :031: :305:
  • Offline Fredz   au
    Offline Fredz
    • Country: au
    Reply #5 on: Aug 29, 2017, 12.37 pm
    I don't know of Jaso M1.  You must mean Jaso MA.  I use this stuff and have for some years now. It's also MA spec.
    http://www.penriteoil.com.au/products/hpr-gas-10-10w-50-semi-syn
     :031:
  • Offline Gaz
    Offline Gaz
    Reply #6 on: Aug 29, 2017, 11.25 pm
    Thanks Fredz. :821:
