Author Topic: Rear Shaft Oil  (Read 3289 times)
  • Offline Gaz
    • Crosstourer Junior  ‐    13
    Offline Gaz
    • Bike: 2016 VFR1200X
    • City / Town: Brisbane
    Rear Shaft Oil
    on: Aug 27, 2017, 03.19 am
    Anyone used fully synthetic SAE 80W-140 gear oil for the rear shaft drive? I have some of this sitting under my workbench and thought it would be good to use for the next change. It is GL6 rated and not cheap. :305:
  • Offline Fredz   au
    • Crosstourer Pro  ‐    118
    Offline Fredz
    • Country: au
    Re: Rear Shaft Oil
    Reply #1 on: Aug 27, 2017, 01.16 pm
    I think that's thicker than what's specifies but would be ok imo.
    Re: Rear Shaft Oil
    Reply #2 on: Aug 27, 2017, 01.55 pm
    Personally, given the cost of oil vs cost of final drive, id stick with what Honda recommend.
  • Offline Gaz
    Offline Gaz
    Re: Rear Shaft Oil
    Reply #3 on: Aug 27, 2017, 10.38 pm
    Thanks Fredz and Hartley. I was just thinking that given the conditions of our summers downunder it wouldn't hurt to have a more heat resistant oil in that drive. :305:
  • Offline Fredz   au
    Offline Fredz
    • Country: au
    Re: Rear Shaft Oil
    Reply #4 on: Aug 28, 2017, 12.07 am
    I wouldn't say it's more heat resistant, just thicker.  GL6 will do the job nicely though being thicker it will 'absorb' a tiny bit more energy from the donk, but I think the 1200 can handle it.
    • Crosstourer Master  ‐    940
    Re: Rear Shaft Oil
    Reply #5 on: Aug 28, 2017, 07.30 pm
    SAE  80 is in the manual
    its been discussed on here before, and i think got a little heated.
    Honda knows best i'm sure!
    so no to 140 spec
  • Offline Fredz   au
    Offline Fredz
    • Country: au
    Re: Rear Shaft Oil
    Reply #6 on: Aug 29, 2017, 06.30 am
    SAE 80 is a generic name for what is typically specified as Gear Oil 75W-80 or 80W-90 API GL5/6.  As the OP's oil is a higher spec than recommended it would be ok to use in the final drive.  The only downside is it's thicker.  Using the manufacturer's recommendations is always a good thing to do, whether it be for oil, tyres or fuel.
     :031:
  • Offline Gaz
    Offline Gaz
    Re: Rear Shaft Oil
    Reply #7 on: Aug 29, 2017, 08.58 am
    Ok. Sounds good. I will go with the 80 oil. Thanks.
