Author Topic: First valve adjustment at 16k miles/24000km  (Read 6632 times)
  • Offline drm4rtin
    • Crosstourer Member  ‐    75
    Offline drm4rtin
    • City / Town: Örnsköldsvik
    on: Apr 15, 2017, 02.57 pm
    Hi! My bike are soon to reach the 24000km (16 k miles). And time for the first valve adjustment/inspection. How many of you have done the first check and really had to adjust? Or has it just been a job just to confirm that the clearance are within specs?
    I'll be out on a long journey when my bike reaches 24000 km, would i be necessary to do the adjustment before the trip, wait until I get home or just skip it (until next 48000km) as long as the bike runs smooth?
    Thanks in advance.
    Last Edit: Apr 15, 2017, 03.08 pm by drm4rtin
    Happiness is not a station you arrive at, but a manner of traveling
  • Offline ohanapoi
    • Crosstourer Member  ‐    22
    Offline ohanapoi
    • City / Town: Half Moon Bay
    Re: First valve adjustment at 16k miles/24000km
    Reply #1 on: Apr 15, 2017, 04.23 pm
    *Originally Posted by drm4rtin [+]
    Thanks in advance.
    Excellent question without a simple answer. The V4 is SOHC..single overhead cam.
    The intake valves are under the cam and are surrounded by a bucket. Bucket unders typically
    don't wear as fast as the rocker arm's do. Your exhaust valves are under the rocker arms. In order
    to adjust the intake clearance, the cams have to be removed and reshimed....ugly. The intakes are far
    simpler and only require a spanner.
    If you are the type of rider that likes to rev your engine up and keep it close to red line then you
    are probably putting significant stress on the valse train. If not and your engine is running smooth and
    there are no unusual sounds coming from the engine I would say go on your ride and don't stress to much
    about it. Take it in for the valve inspection when you get back...
    One caveat, How hard nose is Honda regarding preventitive maintenance and your warranty? Maybe a call to
    your Honda dealer can answer that question or maybe some of the members of this forum have some experience
    with that.
    Suzuki 100 Trail, Yamaha YZ125, Suzuki DR350, Yamaha WR450, Honda VF1100 Sabre, Honda VTX1800, Honda VFR1200X
    • Crosstourer Master  ‐    938
    Reply #2 on: Apr 15, 2017, 04.35 pm
    Hi,
    It is important to inspect valve adjustment, regardless of the make of machine. It is also important to check at the first interval from new as all components have to bed in and what was adjusted correctly at 0 klms may have changed after 24000klms.
    It is also a great feeling when they are inspected / adjusted, that all is good with the internals of the motor ( when it is combined with a service)
    I have had them inspected around 24k and the mechanic said 2 exhaust valves were out of tolerance.
    Around 24 k klms is ok. It is not just the feeling of smoothness but the precise timing of valves, ease of starting,emission control, oil usage and fuel consumption that are affected when they are out of tolerance.
    It takes about 7 - 8 hours to check when combined with a service, so its pretty labour intensive.
    Tom
    Last Edit: Apr 15, 2017, 04.40 pm by thetrecker
  • Offline drm4rtin
    Offline drm4rtin
    Reply #3 on: Apr 15, 2017, 09.32 pm
    *Originally Posted by ohanapoi [+]
    Excellent question without a simple answer...
    OK Thanks! I'm very gentle with the throttle, traveling long distances (northern Sweden, I'm able to travel for 20 minutes sometimes without meeting a single vehicle) at even speed and low revs. Warranty ends in less then1 month. So I feel pretty confident to wait a little bit and a few "over miles" (pardon my lack of english skills) probably wouldn't harm my bike to much.
  • Offline ohanapoi
    Offline ohanapoi
    Reply #4 on: Apr 16, 2017, 04.11 pm
    You'll be fine, go out and take a ride and have some fun, I hear all Swedish girls are a 12 on a scale of 10.
    Is that true?  :156:
  • Offline drm4rtin
    Offline drm4rtin
    Reply #5 on: Apr 16, 2017, 04.22 pm
    Is that true?  :156:
    :001: Well, are they? Off topic, but yupp it's alot of 'em. But to be honest, i think you'll find even better ones i Norway (except for my wife if she eventually reads this) .
  • Offline capobob
    • Crosstourer Pro  ‐    463
    Offline capobob
    • Bike: 2015 HighlanderT
    • City / Town: SE London/Kent
    Reply #6 on: Apr 18, 2017, 10.17 am
    Hi...I had mine inspected at 16K miles....two valves were loose and needed adjustment...I had been able to hear a rattle whilst the engine was cold...
    It all started with a 1959 Vespa 125 Super.......
    KMX125 KMX200 DRBIG 750 TDM800 R1100RS CAPONORD VARADERO.......
  • Offline drm4rtin
    Offline drm4rtin
    Reply #7 on: Apr 18, 2017, 12.35 pm
    Installed my battery this weekend (still zub zero degrees in nothern sweden) just to find out that I haven't reached 10000 miles yet  :431: (15558 km). So I'm able to drive 6000 miles more before any valve adjustment. Well, still "good-to-know" info anyway. Thanks for your replies
