Author Topic: Broke down twice in the last 24 hours -  (Read 11367 times)
  • Offline marcopol
    • Crosstourer Pro  ‐    231
    Offline marcopol
    • Bike: 2013 DCT 2012 DC
    on: Apr 07, 2017, 08.17 am
    2013 1200 DCT. Yesterday I am driving on the motorway with the cruise control engaged when all of a sudden the throttle disengages and refuses to work. I pull into the side of the road and the bike is ticking over but the throttle wont respond when I twist it. Turn bike off and then back on again and everything is OK and I travel on. This morning I am on the bike when it cuts out and I freewheel to the side of the road. All ignition lights on and ticking over. Turn ignition off and back on again. This time the bike wont start, no starter motor engaging. I see the problem, the display says the bike is in second gear and I can hear the DCT clicking trying to bring the bike back to neutral. Turn the bike off and on several times and eventually I get neutral appearing on the dash and the bike starts OK again. Any ideas ????
  • Offline ChrisS
    • Crosstourer Member  ‐    33
    Offline ChrisS
    • Bike: Multistrada 950
    Re: Broke down twice in the last 24 hours -
    Reply #1 on: Apr 07, 2017, 08.43 am
     :112:It might be as simple as a bad connection to the battery or a failing battery. Usually they stick in gear because of weak voltage. That might also explain the drive by wire problems.
  • Offline veeefour
    • Crosstourer Pro  ‐    290
    Offline veeefour
    • Bike: VFR1200F
    Reply #2 on: Apr 07, 2017, 09.43 am
    This means only one thing - dead battery. Might also be a charging problem.
  • Offline marcopol
    Offline marcopol
    Reply #3 on: Apr 07, 2017, 10.21 am
    Battery terminals tight and battery reading 13.2 volts.
  • Offline veeefour
    Offline veeefour
    • Bike: VFR1200F
    Reply #4 on: Apr 07, 2017, 10.25 am
    How old is this battery?
  • Offline marcopol
    Offline marcopol
    Reply #5 on: Apr 07, 2017, 11.09 am
    Alternator output 14.34 V, Battery is 3 years old and correction is reading 13.03 V.
  • Offline Buckr
    • Crosstourer Pro  ‐    291
    Offline Buckr
    • Bike: VFR1200X-DCT
    • City / Town: Walkington
    Reply #6 on: Apr 07, 2017, 11.21 am
    Cruise control problem ??
    What other problems have been reported from the cruise control. I know there was a post but I think it was deleted ?
    Have you tried disconnecting it ?
     :027:
    Last Edit: Apr 07, 2017, 11.26 am by Buckr
    If it ain't fun don't do it !
  • Offline veeefour
    Offline veeefour
    • Bike: VFR1200F
    Reply #7 on: Apr 07, 2017, 11.30 am
    *Originally Posted by marcopol [+]
    You have some voltage problems - you had them before last year when your DCT generated a high idle issue.
    I would still say don't trust the voltmeter because often batteries are dead even tho the voltage is correct.
    *Originally Posted by Buckr [+]
     :027:
    Nothing related to Cruise Control as it uses a brake light as a power source - plus it has 200mA internal fuse
    so it would shut itself million times long before something would be affected.
    There was no post like that - please do not post false information.
