Author Topic: G2 Throttle Tube  (Read 2120 times)
  • Offline ki_ote
    • Crosstourer Member  ‐    20
    Offline ki_ote
    G2 Throttle Tube
    on: Mar 26, 2017, 02.51 am
    Anyone using the G2 throttle tube to combat the snatchiness?
  • Offline FZ1
    • Crosstourer Pro  ‐    261
    Offline FZ1
    • Bike: CT 2012 Manual
    • City / Town: Cambridgeshire
    Re: G2 Throttle Tube
    Reply #1 on: Mar 26, 2017, 09.29 pm
    Yup, several of us using it with really good results.  Search for "throttle tamer" and you'll get the relevant threads.
    Jon
  • Offline ki_ote
    Offline ki_ote
    Reply #2 on: Mar 27, 2017, 07.11 pm
    Thanks, Jon.
  • Offline ki_ote
    Offline ki_ote
    Reply #3 on: Mar 28, 2017, 12.16 am
    What's the trick to getting the actual cables out of the housing?
  • Offline kellyboy
    • Crosstourer Member  ‐    72
    Offline kellyboy
    • Bike: 2014 1200x
    • City / Town: Lincolnshire
    Reply #4 on: Apr 05, 2017, 08.26 pm
    The cables can only be loosened off by accessing the hole in the right side of the chassis which is behind the matt black right side knee/fairing panel. Once you're in there you should see the 2 throttle cables which activate the fuel injection. Both of them have a 10mm or poss 12mm nut which you slacken off (Take a piccie of how much thread they are showing before you loosen them so you can return them to their original position after you finish ) The slack will then allow you to remove the throttle tube cables and fit the G2. I have found the G2 to ease off the jerkiness but not completely eliminate it. If you search the forum you will find the above job posted with pix. I cant help you by adding links to them 'cos I'm computer dinosaur-sorry.
  • Offline Superjeap
    • Crosstourer Pro  ‐    375
    Reply #5 on: Apr 05, 2017, 08.57 pm
    What's the trick to avoid putting   under every post?   :164:
  • Offline ki_ote
    Offline ki_ote
    Reply #6 on: Apr 06, 2017, 03.57 am
    Ah, thanks kellyboy. I'll have a look this weekend. Much obliged.
