Author Topic: Rear brake calliper and disc getting very hot  (Read 6523 times)
  • Offline marcopol
    • Crosstourer Pro  ‐    231
    Offline marcopol
    • Bike: 2013 DCT 2012 DC
    on: Jan 10, 2017, 12.23 pm
    Under normal riding conditions around town has anyone noticed if their rear calliper or disc gets hot ?
    I have cleaned the calliper pistons and springs etc by the way
  • Offline GADGET
    Re: Rear brake calliper and disc getting very hot
    Reply #1 on: Jan 10, 2017, 12.54 pm
    Is it the parking brake causing the drag?
  • Offline marcopol
    Offline marcopol
    Reply #2 on: Jan 10, 2017, 02.30 pm
    Checked that as well there is mild drag here, doesn't stop the wheel from turning if I push the wheel by hand though.
  • Offline mondeoman
    • Crosstourer Pro  ‐    203
    Offline mondeoman
    • Bike: vfr1200X
    Reply #3 on: Jan 10, 2017, 03.19 pm
    Should not be any drag from the brake pads touching the disc, but remember by rotating the rear wheel you're turning the drive shaft and a gearbox shaft so there will be resistance from them, if the disc IS getting hot that can only be caused by the pads contacting the disc with SOME pressure, either it's the h/brake not freeing properly or the caliper sticking a bit, you need to get it seen too.  :034:
  • Offline marcopol
    Offline marcopol
    Reply #4 on: Jan 10, 2017, 08.53 pm
    I just rode the bike at speed for 30KM and only used the front brakes. When I stopped I checked the rear disc and caliper and they were cold, therefore the tiny drag I noticed has no affect in generating heat. So the heat is obviously only generated when using the brakes. Can someone check their rear disc after they have ridden their bike and see how hot it is please.
  • Offline mondeoman
    Offline mondeoman
    • Bike: vfr1200X
    Reply #5 on: Jan 10, 2017, 09.40 pm
    *Originally Posted by marcopol [+]
    There's nothing wrong then, it would be hot within a few miles if there was incorrect pad contact, discs do get hot of course with brake use, (depends how often you're using the brakes of course,) nothing wrong with yours it looks like.
  • Offline joe@lgpafo
    • Crosstourer Junior  ‐    5
    Offline joe@lgpafo
    Reply #6 on: Jan 11, 2017, 01.17 am
    It might be worth remembering the Crosstourer uses the Honda Combined Braking System so it applies brake pistons at both wheels regardless of which brake lever you are operating, which might lead to a bit of unexpected heating of the rear brakes/discs if the front brakes have been used to any great extent. Just a thought.
  • Offline Fredz   au
    • Crosstourer Pro  ‐    118
    Offline Fredz
    • Country: au
    Reply #7 on: Jan 11, 2017, 01.44 am
    *Originally Posted by joe@lgpafo [+]
    Not so.
