Author Topic: Advice please guys.....  (Read 3945 times)
  • Offline Jumper
    • Crosstourer Member  ‐    83
    Offline Jumper
    • Bike: Highlander DCT
    • City / Town: Southampton
    on: Dec 17, 2016, 03.33 pm
    Just in the process of fitting one of these to the cockpit area of the Crosstourer......,
    My question is, does the unit draw power ONLY when being used with USB device plugged in and therefore able to be connected to battery, or permanently, due to whatever drops the voltage and therefore likely to flatten battery during periods of bike non use?
    Regards, Dave
    Re: Advice please guys.....
    Reply #1 on: Dec 17, 2016, 06.16 pm
    Hi Jumper, i dont know the answer, but, could you use a multi meter to see if there is any draw on the unit.  :084:
    I always thought that if you fed straight to the battery via an inline fuse then it only worked if ignition was on.  :027:
    If there is nothing plugged in then surely it can not take power out.
    Please anyone correct me if im wrong and i do guarantee to bit someones head off just because they know more than me, because that aint hard. ha.  :028:
    pistnbroke
  • Offline Jumper
    Offline Jumper
    Reply #2 on: Dec 17, 2016, 07.45 pm
    Hi Pistn, Thanks,  that was going to be my next step...... my thinking though is 'something' must be working to alter the 12v battery supply down to the 5v USB supply.......
    Everything a bit complicated at the moment because of postcancer treatment meds being taken and fudging the brain  :087: :087:
    Regards, Dave
  • Offline fastnlight
    • Crosstourer Pro  ‐    168
    Offline fastnlight
    • Bike: 2016 DCT
    • City / Town: Gig Harbor, WA
    fastnlight
    Reply #3 on: Dec 18, 2016, 06.49 am
    As long as it doesnt have an led light on it or other power drawing indicator, it should not draw power when nothing is left plugged in.
    Greg
    The Beaten Path is for Beaten People
    Reply #4 on: Dec 18, 2016, 01.50 pm
    All the very best with the treatment and cocktail of meds Jumper.
    Keep thinking of next years tour,.
    Great location you live in for hopping over the channel for a few days bimble hey.
    Take care jumper, pistnbroke.  :028:  :031:
  • Offline Jumper
    Offline Jumper
    Reply #5 on: Dec 18, 2016, 02.28 pm
    *Originally Posted by pistnbroke [+]
     :031: :031: looking forward to it and yes, xtourer on the xchannel is planned!
    Regards, Dave
  • Offline marcopol
    • Crosstourer Pro  ‐    231
    Offline marcopol
    • Bike: 2013 DCT 2012 DC
    Reply #6 on: Dec 19, 2016, 08.32 am
    I have mine wired directly to the battery. No LED then no power drain.
    In fact my USB charger has a cigarette lighter socket attached to it also which I use to trickle charge the bike if it is not going to be used for extended periods.
  • Offline Jumper
    Offline Jumper
    Reply #7 on: Dec 20, 2016, 11.43 am
    Ok, a bit of an update....... connected the USB sockets direct to battery and, as suspected, even though there is no green led on my socket, I get a drain of 25ma with nothing plugged in so therefore, over a considerable period, I will be flattening the battery. So my quest for a switched 12v under the seat continues......seen I post where the feed to the rear brake light switch is used, but on mine, I can't locate the bloody switch lol!
    Regards, Dave
