Author Topic: Throttle Tamer  (Read 14042 times)
  • Offline dens
    • Crosstourer Member  ‐    66
    Offline dens
    • Bike: CT & BMW RACER
    • City / Town: Newtownards
    Throttle Tamer
    on: Nov 26, 2016, 07.29 am
    Hi can someone confirm that a 40-4F-130 THROTTLE TAMER TUBE fits a 2016 Crosstourer. MandP list this one for a 2010 to 13 model and I think the 2016 model is the same. Perhaps one of our friends in the USA might be able to shed some light on this as I think this is were they are made
    Thanks
    Dens
  • Offline FZ1
    • Crosstourer Pro  ‐    261
    Offline FZ1
    • Bike: CT 2012 Manual
    • City / Town: Cambridgeshire
    Re: Throttle Tamer
    Reply #1 on: Nov 26, 2016, 08.50 am
    Hi Dens,
    If you give the folks at G2 Ergonomics a shout (the manufacturer), they will confirm your model for you.  I  did this for my 2014 model and they were really helpful.
    email is: street.tech@g2ergo.com
    Cheers,
    Jon
  • Offline dens
    Offline dens
    Re: Throttle Tamer
    Reply #2 on: Nov 26, 2016, 09.28 am
    Hi FZ1 thanks for your quick reply. I have sent them an email
    I had a 2012 Crosstourer and the fuelling was good but the 2016 one I have now being Euro 4 is snatchier in comparison so I hope a Tamer should sort it
    Thanks
    Dens :152:
  • Offline mjb9
    • Crosstourer Pro  ‐    149
    Offline mjb9
    Re: Throttle Tamer
    Reply #3 on: Dec 03, 2016, 02.15 am
    I have the 2016 VFR1200X USA version with this http://www.g2ergo.com/store/g2-street-tamer-throttle-tube/?fueid=77784&qid=4795
    Fits perfectly and definitely tames the jerkiness down quite a bit. You have to give up OEM heated grips though. However, I wasn't too impressed with them anyway. So, I went with this heated grip solution and love it (Just don't use the shrink tubing-skit it)! Also went with these grips as it give the hand a lot more to hold on to AND also helps even more with throttle control! :-)
    https://www.amazon.com/gp/product/B001AWRCJO/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    the below image looks lousy and washed out but the grips are quality and I may get a 2nd set in case I ever need to replace them. They were hard to find as I tried a lot of grips and these are awesome!
    https://www.amazon.com/gp/product/B0022ZMM8O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  • Offline dens
    Offline dens
    Re: Throttle Tamer
    Reply #4 on: Dec 09, 2016, 02.07 pm
    Hi I emailed Ergonomics as suggested by FZ1 and got a swift reply with the info. I ordered one and promptly went for a weeks holiday in the sun and when I returned there it was sitting on hall floor.  Great service
    Now the fun starts , being a tight git I have to try and remove the Oxford heated grip from the original throttle tube failing that I will buy a replacement one. Any ideas? I'll maybe cut the tube out  :087:
     Hope it fixes the jerkyness
  • Offline dens
    Offline dens
    Re: Throttle Tamer
    Reply #5 on: Dec 26, 2016, 12.28 pm
    Hi I have finally fitted the throttle tamer and I have to say it has transformed the fuelling at slow speed. Around 20 to 50 mph over uneven surfaces it is a lot smoother with no hint of jerkyness. I feel it is expensive for what it is but I can't recommend it highly enough. Perfect  fit using original cables etc and easy to fix on the bars
    Problem solved  :047:
  • Offline Big Bob
    • Crosstourer Pro  ‐    353
    Offline Big Bob
    • City / Town: Perth
    Re: Throttle Tamer
    Reply #6 on: Dec 27, 2016, 02.54 am
    Why can't you use the heated grips
  • Offline dens
    Offline dens
    Re: Throttle Tamer
    Reply #7 on: Dec 27, 2016, 07.30 am
    The Oxford heated grip was super glued to the original plastic throttle tube therefore hard to remove but I purchased a replacement grip and used that instead. So all good , no jerkyness and warm hands
