Author Topic: Cruise control update  (Read 4442 times)
  • Offline MSB
    • Crosstourer Member  ‐    25
    Offline MSB
    • City / Town: Ft Myers Florida
    on: Nov 04, 2016, 12.32 pm
    Its been about 6 months with my VeeFour ECC cruise control, and its been awesome! The unit has performed flawlessly! I am not sure why Honda does not offer this on our bikes. I am sure they have a proven unit from their cruiser and goldwing models so its not like its a foreign concept to them. When I was deciding between the GS1200 and VFR1200X i was leaning heavily to the GS just for the cruise option until I found the ECC unit. Well worth the time and money!
  • Offline veeefour
    • Crosstourer Pro  ‐    290
    Offline veeefour
    • Bike: VFR1200F
    Re: Cruise control update
    Reply #1 on: Nov 04, 2016, 01.48 pm
     :031: :0461:
  • Offline DervMan
    • Crosstourer Member  ‐    47
    Offline DervMan
    • Bike: R1200GS
    • City / Town: Bristol
    Reply #2 on: Nov 04, 2016, 08.44 pm
    I'm confident the next model update with have cruise and a LED headlight.....  :440:
  • Offline Paul82
    • Crosstourer Member  ‐    56
    Offline Paul82
    • Bike: 2012 VFR1200X
    • City / Town: Yanchep
    Reply #3 on: Nov 05, 2016, 01.13 am
    I've fitted my old Audiovox vacuum cruise control off my Tiger 1050 to my CT, It worked ok after fitting it & ok on the Freeway with no gear on board since then. But I went for a 1000km ride last weekend, bike all loaded up, hills & headwind & the old CC was useless most of the way.
    I've been using this sort of old Vacuum CC for over 10 years on a few of my cars & bikes & they are quite temperamental & annoying have to keep making adjustments, sometimes they work ok, sometimes they don't. I can set it to a speed & it can randomly drop 10+kph for no apparent reason. Headwinds it does't work, it just will not pull the throttle enough & continuously looses speed. & sometimes it goes ok up hills & other times it doesn't! It works ok on the flat Freeway with no gear on it, but when I Really want to use it on a decent long ride, it let me down...
    I've had enough of it, going to get rid of it & get VeeFour ECC cruise control & be done with it.  :001:
     :821:
    Last Edit: Nov 05, 2016, 01.17 am by Paul82
  • Offline Fredz   au
    • Crosstourer Pro  ‐    118
    Offline Fredz
    • Country: au
    Reply #4 on: Nov 05, 2016, 02.22 am
    I wonder how the latest version will perform with a fully loaded bike, uphill & headwind.
  • Offline Paul82
    Offline Paul82
    Reply #5 on: Nov 05, 2016, 02.39 am
    *Originally Posted by Fredz [+]
    Latest version? You mean VeeFour's Electronic cruise control? He says it works near on perfectly in those conditions.
  • Offline veeefour
    Offline veeefour
    • Bike: VFR1200F
    Reply #6 on: Nov 05, 2016, 06.38 am
    *Originally Posted by Paul82 [+]
     :821:
    :028:
    Check my YT channel - you will find some videos that should convince you that this is not an issue. Trust me - it works just fine.
    If you still have some doubts I can always increase the max. allowed open throttle percentage - default 40%.
    Last Edit: Nov 05, 2016, 08.48 am by veeefour
