Author Topic: DCT handbreak tension mechanism. Corrosion  (Read 1847 times)
Offline Bitteliten
  • Country: Norway
on: September 13, 2013, 08:01:04 PM
I pulled down the rubber protection to tighten the hand break on my CT yesterday. Discovered white corrosion on the mechanism. Had to use some force to move it. Used spray chain grease to protect from more corrosion. I recommend that you check this on your bike.
My bike is always parked in the garage, and is not used in wet conditions. Used 3500 km.  I was surprised to see this.
