Author Honda OE top box bracket  (Read 1947 times)
  • Offline karlmalcolm@telia.com
    • Crosstourer Junior  ‐    5
    • Bike: VFR 1200 X
    on: Mar 01, 2013, 05.56 pm
    Got the OE top box and panniers. Fitted the mounting bracket for the top box and the instructions say that there should be sideways movement (few mm). However, I find that there you can also lift the bracket a few mm -- is this right/normal?
  • Offline paperman
    • Crosstourer Member  ‐    77
    Offline paperman
    • City / Town: Bromborough
    Re: Honda OE top box bracket
    Reply #1 on: Mar 01, 2013, 06.06 pm
    Hello karlmalcolm
    I just run down to my garage to check. There is a few mm movement side to side, but very little up and down, I would say only 1mm or less when lifting from the rear of the plate.
    • Bike: VFR 1200 X
    Reply #2 on: Mar 01, 2013, 06.14 pm
    Just read on the Honda ST1000 forum that it has been discussed there too. So I belive it must be right? Apparently to do with aerodynamics and all??
