Finally fitted my hugger a few weeks ago and reporting back now. Pictures to follow.
Good points
Nice carbon fibre finish.
Strong steel bracket mounts first to the swing arm and then the hugger bolts to this.
Extra stay to the side that bolts to existing bolt for plastic guard around the diff.
Good and wide to catch more spray.
Good instructions.
Bad points
bracket is electroplated only and i sprayed it with a few coats of primer/black to help prolong its life and help blend in.
All Bolts are BZP only, I changed them all for stainless steel.
It does'nt cover the lower link like the Pyramid one mentioned on this forum.
It being so wide ( I think it was designed for the VFR F) it does'nt "hug" the wheel and makes the tyre look skinny
