DSC 7177
Posted by: Bus
in: Bus
Eifel 20130519 3 Forum
Posted by: CrossALL
in: CrossALL
nc700 vfr1200
Posted by: luckyluke
in: Luckyluke
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Removing Panels  (Read 4750 times)
Offline russ_fae_fyvie
  • Bike: CT
  • City / Town: Fyvie
Removing Panels
« on: August 07, 2012, 08:16:55 AM »
As I only picked up my bike on Friday I have a quick question regarding removing the plastics.
I got a set of Givi Crashbars last week and need to take the side panels off to fit them.
After a quick look I saw 2 outer screws and 2 inner pop fasteners at the top. However after removing them the panel refused to budge and I didn't want to just start pulling in case a hidden fastener broke.
Anyone taken them off yet and is there any extra fasteners I can't see ?
Online thetrecker
Re: Removing Panels
« Reply #1 on: August 07, 2012, 05:55:34 PM »
Hi Russ, removing side panel- 2 silver panel screws, 4 pop type plastic clips, 2 at dash area(press in the centre button to pop them) and2 in behind (above the radiator) then ease the panel out to you and forward towards the front of the bike to remove it off 3 lugs in slots on the rear of the panel (not visible when the panel is in position), one at the front and two at the top. hope this helps. i fitted the Honda crash bars and the instructions are very poor in that it suggests the panels have to be removed to fit the mounting brackets up under the light fitting, which is true, then when the crash bar is fitted it says to then refit the side panels which is impossible! the crash bar must be loosened at the front and hinged down to sit on the front mud guard to allow just enough room to slot in the side panels. hope this makes sense :174:
« Last Edit: August 12, 2012, 09:45:43 PM by thetrecker »
  • Bike: CT
Re: Removing Panels
« Reply #2 on: August 08, 2012, 07:28:28 AM »
Thanks for that !
Yeah the instructions are pretty pathetic really, a few photos and not a lot else !
Thanks for the info on removing the panels, I will need to get some sort of workshop manual, I usually do for my bikes, saves breaking things with brute force and ignorance  like I usually do !!
Cheers !!
 :031:
Offline marvincon
  • Bike: NC750 dct
  • City / Town: leics
Re: Removing Panels
« Reply #3 on: August 11, 2012, 08:24:31 PM »
Took my LH panel off this evening to connect satnav feed, before pushing panel forward, with 2 screws & 4 plastic push pins all out , the RHS of the panel needs to be pulled out 20 mm  to release another fixing. I was struggling to push it forward until I discovered this.
  • Bike: CT
Re: Removing Panels
« Reply #4 on: August 13, 2012, 12:24:12 PM »
Thanks for the info, I got both panels off at the weekend and got the Givi Crash Bars on with no problem.
It was good to find out about pushing the panels forward because if I hadn't know that it would have been quite easy to break something off by trying to pull them off sideways.
Dead easy when you know !!
 :031:
Re: Removing Panels
« Reply #5 on: September 19, 2012, 05:03:11 PM »
Folks
If anyone has done this and has time to take pictures showing the location of the fasteners and lugs then I think this would be very useful as no doubt at some time, even just for cleaning, most people will take these panels off.
As has been mentioned sounds easy to break a lug if you don't know it's there  :031:
Offline Nickel
  • www.docraphotography.be
Re: Removing Panels
« Reply #6 on: September 20, 2012, 07:52:52 AM »
*Originally Posted by Mika [+]
:435:
Do you have to clean it????
Offline tsodeq
  • City / Town: Bologna
  • Country: Italy
Re: Removing Panels
« Reply #7 on: December 29, 2013, 10:43:20 AM »
Folks
et voilà
".. you feel good wind .. never enough time .."
