2012 07 29 10 51 24
Posted by: iec
in: iec
IMGP3411
Posted by: jacob
in: Jacob
108
Posted by: russ
in: russ
Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Which OIL ?  (Read 12191 times)
Offline grahew
  • White very fast CT
  • Bike: Honda CT
  • City / Town: Evesham
Which OIL ?
« on: July 23, 2012, 08:56:13 PM »
Which Oil grade is suitable for topping up? in the manual it says 10-30w but is it fully or part synthetic,ans can other grades be used i.e. 10-40 etc :159:
Offline ojo
  • Bike: VFR 1200XD white
  • City / Town: Stans
  • Country: Switzerland
Re: Which OIL ?
« Reply #1 on: July 23, 2012, 10:43:27 PM »
First to say it's very unlikely that you will have to top up any oil between services  :028: ... mine was just fine even until big service at 12'000km.
However, you may ask your dealer what they fill up.
Offline peace
  • Bike: VFR1200X~RED
  • City / Town: JayBee
  • Country: Singapore
Re: Which OIL ?
« Reply #2 on: July 24, 2012, 08:58:48 AM »
Well i did heard my usual patron mechanic said that we should monitor the engine oil level but forgotten what the reason behind it....   :006:
~Never Ever Give Up~
Offline ojo
Re: Which OIL ?
« Reply #3 on: July 24, 2012, 02:30:00 PM »
Sure you must check oil level in a regular way although it's not likely that CT will use much oil between services. However, with heavy use if the engine heats up exceptionally as for example on a racetrack you'd sure have to check more often too.
I am going on a 5 .... -  6000km trip next week, i dont take any "spare" oil with me - however - if i'd have to top up i would look for a high grad motorcycle specific oil, probably fully synthetic yes. In an odd situation if nothing else available i wouldn't care too much on what oil to top it up ....
Re: Which OIL ?
« Reply #4 on: July 24, 2012, 07:58:00 PM »
Hi Grahew,
its not necessary to fill with full synth,really you need to avoid mixing full with semi. The oil spec in the CT is rather old hat and if you want a direction i suggest Silkolene COMP4 10-30 SEMI SYNTH, IT MEETS ALL THE REQUIRMENTS, (ie) Jaso MA, sae SG or higher,it seems to be available in most bike shops and all the on line shops (like M+P OR demon tweeks) stock it. its an oil grade used in most Hondas built in the last few years. As i say Dont mix full with semi!. hope this helps
Offline ojo
Re: Which OIL ?
« Reply #5 on: July 24, 2012, 08:20:46 PM »
Thanks trecker ... that's good infos  :062:
Offline Chrippen
  • Have fun
  • Bike: Vfr 1200 x black
  • City / Town: Kristianstad
  • Country: Sweden
Which OIL ?
« Reply #6 on: July 24, 2012, 09:58:39 PM »
i needed 3 dl oi, after 500 km from service I am now looking all the time.......hopefully the guy who did it did it bad...
Re: Which OIL ?
« Reply #7 on: July 25, 2012, 07:42:39 PM »
Hi Chrippen, dont quite understand your problem, are you saying the CT is using oil or it is leaking, some new engines use oil and it will stop using after a few thousand klms, nothing to worry about, just important to keep checked. do you know what type/grade of oil he used?
